[GRASS-user] Redraw canvas of the Graphical Modeler does not work
under Windows
Martin Landa
landa.martin at gmail.com
Sun Nov 6 18:11:31 EST 2011
2011/11/6 Filipe Silva Dias <filipesdias at gmail.com>:
> I built a model with a lot of actions and at some point I moved one of the
> actions out of the visible canvas. I pressed Redraw Model Canvas to be able
> to select it and move it closer to the others,but the window didnt resize. I
> tried to use the scroll bars but I couldnt. Now I cant click or select the
> action that is "out of the visible" window.
> Is there something wrong with the graphical modeler window or am I missing
> something?
> Im using GRASS 6.4.2 RC1 and GRASS 7 svn under Windows 7 64 bit. Under
> LInux Ubuntu everything works fine.
> (Also: If I select parametrize in any action and the press Run, the model
> doesnt run. Nothing happens when I press it)
there were quite a lot of changes in the modeler since 6.4.2RC1, could
you try GRASS 6.5 [1]?
Martin
[1] http://wingrass.fsv.cvut.cz/grass65/
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
