[GRASS-user] Creation of GISDBASE in a script
Rainer M Krug
r.m.krug at gmail.com
Tue Nov 8 05:52:38 EST 2011
On Tue, Nov 8, 2011 at 11:40 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Nov 8, 2011 at 9:51 AM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> > One disadvantage though: as the location has to be on a shared volume,
> all
> > data has to be transfered via the network backend of the cluster. If you
> > need the data often, it might be considerably faster to copy the data to
> the
> > local volume of the node, and work there and copy the results back.
> Yes, see this script as an example:
> http://grass.osgeo.org/wiki/Parallel_GRASS_jobs#The_Grid_Engine_script
> # temporarily store *locally* the stuff to avoid NFS overflow/locking
> problem
> ## Remove XXX to enable
> grep XXX/storage/local /etc/mtab >/dev/null && (
> if test "$MYMAPSET" = ""; then
Very nice script - I might add some aspects to my script.
Cheers,
Rainer
> Markus
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111108/ec094778/attachment-0001.html
