[GRASS-user] r.in.wms failure
    Paul Shapley
    p.shapley at gmail.com
    Thu Nov 10 07:59:30 EST 2011
I'm getting the following error telling me gdalwarp has failed. I'm using
the windows version of Grass 6.4.2RC1. Any help appreciated as usual.
Paul Shapley
(Thu Nov 10 11:49:41
2011)
r.in.wms output=grass_wms_request mapserver=mapserver=
http://120.100.200.96:8080/geowebcache/service/wms?tiled=truelayers=os_imagery_2010
format=jpeg maxcols=1024 maxrows=1024
folder=folder=\\innogistic\mapping\test method=nearest
Calculating tiles
Requesting 1 tiles.
mkdir: cannot create directory
`folder=\\innogistic\\mapping\\test': No such file or
directory
C:/Program Files/GRASS 6.4RC1/etc/r.in.wms/wms.request: line
221:
folder=\innogistic\mapping\test/grass_wms_request_.wget: No
such file or directory
223:
folder=\innogistic\mapping\test/grass_wms_request_.proj4: No
240:
folder=\innogistic\mapping\test/grass_wms_request__0.jgw: No
241:
242:
243:
244:
245:
248:
Downloading tiles
cat:
All tiles downloaded successfully
cat:
folder=\\innogistic\mapping\test/grass_wms_request_.wget: No
file: could not find any magic files!
ERROR: Required parameter <input> not set:
        (Raster file or files to be imported. If multiple
files are specified they will be patched together.)
Description:
 Warps and imports GDAL supported raster file complete with
correct NULL values
Keywords:
 raster, rotate, reproject
Usage:
 r.in.gdalwarp [-peck] input=string[,string,...]
output=string
   s_srs=string method=string [warpoptions=string]
[--verbose] [--quiet]
Flags:
  -p   Don't reproject the data, just patch it.
  -e   Extend location extents based on new dataset
  -c   Make color composite image if possible
  -k   Keep band numbers instead of using band color names
 --v   Verbose module output
 --q   Quiet module output
Parameters:
        input   Raster file or files to be imported. If
multiple files are specified they will be patched together.
       output   Name for resultant raster map. Each band
will be name output.bandname
        s_srs   Source projection in gdalwarp format
       method   Reprojection method to use
                options: nearest,bilinear,cubic,cubicspline
                default: nearest
  warpoptions   Additional options for gdalwarp
ERROR: r.in.gdalwarp failed
(Thu Nov 10 11:50:10 2011) Command finished (29 sec)
Paul J. Shapley
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111110/da1c4665/attachment.html
