[GRASS-user] Re: How can i modify the algorithm/code for
Hydrologic Modeling or watershed analysis?
Daniel Lee
lee at isi-solutions.org
Sat Nov 12 02:58:19 EST 2011
I didn't answer right away because I am far from being an expert, but a
colleague and I have done this before. You have to download and compile the
GRASS source. Then you can navigate into the directory with the code you
want to change, change it, and recompile that. GRASS should use it without
even having to be restarted. However, I have no idea where you'd find the
specific code for watershed analyses. Try using the find or locate command,
if you're working in a *NIX system. Otherwise I'm afraid I don't have any
other suggestions.
Best,
*Daniel*
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions
Deutschhausstr. 10
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
ISIS wird gefördert durch die Bundesrepublik Deutschland, Zuwendungsgeber:
Bundesministerium für Wirtschaft und Technologie aufgrund eines Beschlusses
des Deutchen Bundestages, sowie durch die Europäiache Union,
Zuwendungsgeber: Europäischer Sozialfonds.
Zusätzliche Unterstützung erhält ISIS von dem Entrepreneurship Cluster
Mittelhessen, der Universität Marburg, dem Laboratory for Climatology and
Remote Sensing und dem GIS-Lab Marburg.
Am 12.11.2011 07:05 schrieb "Sandip Maity" <sandip.stesalit at gmail.com>:
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111112/5ba14722/attachment-0001.html
