[GRASS-user] GRASS 7 error code 9
Glynn Clements
glynn at gclements.plus.com
Thu Nov 17 10:16:44 EST 2011
Pankaj Kr Sharma wrote:
> I am getting error " WARNING: Subprocess failed with exit code 9 " from
> r.watershed command , whenver I use more than 8.5 gb ram.
The "exit code 9" could either refer to an exit status or a signal. I
suspect it's the latter. Signal 9 is SIGKILL, which may be sent by the
kernel to a process which is using too much memory.
