[GRASS-user] how to count number of occurrences of a specific
	category value in the neighborhood of a given pixel
    Marcello Gorini
    gorini at gmail.com
    Wed Nov 23 11:41:16 EST 2011
Moritz:
Hello,
> Does anyone see an easy way to count the number of times a specific
> category value occurs in a given neighborhood of a central pixel ?
As always, there is surely a better way in GRASS (probably one single
command), but you could binarize your map (1 for your desired category and
zero for everything else) and then use r.neighbors method=sum
size=desired_neighborhood.
The result would be the desired count.
Cheers,
Marcello.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111123/b7417f8e/attachment.html
