[GRASS-user] LiDAR LAS import
Markus Metz
markus.metz.giswork at googlemail.com
Fri Nov 25 07:29:36 EST 2011
Daniel Victoria wrote:
> I removed the ubuntu Liblass and compiled the latest version by hand.
> Grass compilation went fine but unfortunatelly I still can't test it
> because I'm having some other problems. Location Wizard is not opening
> and when I try to open v.in.lidar I get:
> python: can't open file
> '/home/daniel/grass_src/grass_trunk/dist.i686-pc-linux-gnu/etc/gui/wxpython/gui_modules/menuform.py':
> [Errno 2] No such file or directory
> Something probabli went wrong during compilation...
That's because the gui file organisation is currently changing. It
seems that paths have not yet been updated.
Markus M
> On Fri, Nov 25, 2011 at 6:17 AM, Markus Metz
>>> Hi Rebecca et al.,
>>> I'm having the same problem. Installed liblas using ubuntu packages
>>> and when I run configure I get that it's unable to locate libLAS
>>> library.
>>> daniel at daniel-desktop:/usr/lib$ liblas-config --libs
>>> -L/usr/lib -lgeotiff -L/usr/lib -lgdal1.6.0
>>> daniel at daniel-desktop:/usr/lib$ liblas-config --includes
>>> -I/usr/include/geotiff -I/usr/include/gdal
>>> Has anyone figured out what is going on?
>> I think I got it. LibLAS 1.6.1 and 1.7.0: liblas-config --libs
>> -L/usr/local/lib -llas -llas_c -L/usr/lib64
>> /usr/lib64/libboost_program_options-mt.so
>> /usr/lib64/libboost_thread-mt.so /usr/local/lib64/libgdal.so
>> /usr/local/lib64/libgeotiff.so /usr/lib64/libtiff.so
>> /usr/local/lib64/liblaszip.so
>> The crucial difference is -llas -llas_c which is missing for libLAS 1.2
>> Maybe this (-llas -llas_c) should be always included by configure for libLAS ?
>> Markus M
>>> Thanks
>>> Daniel
>>> On Fri, Jul 29, 2011 at 8:10 AM, Rebecca Bennett <rabennett at ymail.com> wrote:
>>>> sorry for the delayed reply - (windoze day yesterday)
>>>>>Hmm. Is lasinfo --help working?
>>>> Yes. wont paste the output here but it is as expected.
>>>> Thanks,
>>>> Rebecca
>>>> ________________________________
>>>> From: Markus Metz <markus.metz.giswork at googlemail.com>
>>>> To: Rebecca Bennett <rabennett at ymail.com>
>>>> Cc: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
>>>> Sent: Wednesday, 27 July 2011, 18:01
>>>> Subject: Re: [GRASS-user] LiDAR LAS import
>>>> On Wed, Jul 27, 2011 at 3:28 PM, Rebecca Bennett <rabennett at ymail.com>
>>>> wrote:
>>>>> sure -
>>>>> checking whether to use libLAS... yes
>>>>> checking for liblas-config... /usr/bin/liblas-config
>>>>> configure: error: *** Unable to locate libLAS library.
>>>>> I have the packages liblas1, liblas-dev, lib-las-bin and python-liblas
>>>>> installed through synaptic and am wondering if there is a libraty package
>>>>> missing?
>>>> What does
>>>> and
>>>> say?
>>>>> Sent: Wednesday, 27 July 2011, 13:16
>>>>> Rebecca Bennett wrote:
>>>>>> Hello,
>>>>>> Just trying to install GRASS 7 on Ubuntu 10.04 to try out the las import
>>>>>> functions but I'm getting error messages during the configure that it is
>>>>>> unable to find the liblas library, however the liblas library is
>>>>>> installed
>>>>>> in usr/bin/lib/ so I'm a bit puzzled...
>>>>> Can you post the exact error message? Also, liblas support will only
>>>>> be available if liblas-config exists.
>>>>> Markus M
>>>>>> Did anyone else get stuck here or am I missing something obvious?
>>>>>> Thanks for reading,
>>>>>> Rebecca
>>>>>> To: Hamish <hamish_b at yahoo.com>
>>>>>> Cc: grass-user <grass-user at lists.osgeo.org>; GRASS developers list
>>>>>> <grass-dev at lists.osgeo.org>
>>>>>> Sent: Wednesday, 25 May 2011, 12:48
>>>>>> On Wed, May 25, 2011 at 12:16 PM, Hamish <hamish_b at yahoo.com> wrote:
>>>>>>> Markus Metz wrote:
>>>>>>>> Hi all,
>>>>>>>> GRASS 7 has a new module v.in.lidar for importing LiDAR LAS files
>>>>>>>> (*.las or *.laz). The LAS file format is commonly used for storing
>>>>>>>> LiDAR point clouds, but is unfortunately not supported by OGR.
>>>>>>>> v.in.lidar uses the libLAS library [0] and is only compiled if the
>>>>>>>> libLAS library is present.
>>>>>>>> I chose to use the library instead of writing a custom LAS reading
>>>>>>>> interface because the current LAS library version 1.6.1 is stable,
>>>>>>>> supports LAS file versions 1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, each of
>>>>>>>> which can store LiDAR points in up to 5 different point formats. The
>>>>>>>> user and the interface do not need to know the file version and point
>>>>>>>> format of a given file, all that is conveniently handled by the libLAS
>>>>>>>> library in the background. The library has Large File Support (LFS)
>>>>>>>> and is well tested on different platforms, also with different
>>>>>>>> endian-ness. This functionality is not that easy to replicate.
>>>>>>>> You will need to get the libLAS library and configure GRASS 7 with
>>>>>>>> --with-liblas in order to have the module available. Please test!
>>>>>>>> Markus M
>>>>>>>> [0] http://www.liblas.org
>>>>>>> neat! any time trials to say how much faster it is than piping
>>>>>>> las2txt | v.in.ascii
>>>>>> Note that las2txt does NOT apply scale and offset to x,y,z, this would
>>>>>> need to be done afterwards in order to obtain correct coordinates.
>>>>>> Therefore the output of las2txt | v.in.ascii with the sample las file
>>>>>> I used is incorrect.
>>>>>> I discovered a bug in v.in.ascii: from a point file with | as field
>>>>>> separator like
>>>>>> 1|2|3||5|6
>>>>>> only the first 3 columns will be imported because column 4 is empty
>>>>>> which means that columns 5 and 6 are skipped.
>>>>>> v.in.lidar is a notch faster than las2txt | v.in.ascii. And easier to
>>>>>> use...
>>>>>> Speed comparisons:
>>>>>> # sample las file with 1,287,775 points
>>>>>> # with table and topology
>>>>>> time las2txt -i points.las --stdout --parse xyztinrcCpedRGBau
>>>>>> --delimiter "|" | v.in.ascii in=- out=points_ascii -z x=1 y=2 z=3 --o
>>>>>> real 6m34.430s
>>>>>> user 4m57.530s
>>>>>> sys 2m3.693s
>>>>>> time v.in.lidar in=points.las out=points_las -o --o
>>>>>> real 6m13.823s
>>>>>> user 4m32.061s
>>>>>> sys 2m1.068s
>>>>>> # without table, with topology
>>>>>> time las2txt -i points.las --stdout --parse xyz --delimiter "|" |
>>>>>> v.in.ascii in=- out=points_ascii -zt x=1 y=2 z=3 --o
>>>>>> real 1m53.578s
>>>>>> user 1m47.032s
>>>>>> sys 0m9.238s
>>>>>> time v.in.lidar in=points.las out=points_las -ot --o
>>>>>> real 1m44.876s
>>>>>> user 1m34.450s
>>>>>> sys 0m8.488s
>>>>>> _______________________________________________
>>>>>> grass-user mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
