[GRASS-user] Runtime error! / Program: C:\Osgeo4w\bin\python.exe
    Johannes Radinger
    JRadinger at gmx.at
    Mon Nov 28 08:53:51 EST 2011
Maybe that is causing the problem (as it did in my case!)
Via the advanced setup you can you can choose 4.0.0dev-90.
This works in my case. But you have to be careful then
with the make (the one you installed manually) this can be
updated and overwritten by the osgeo4w setup with the old version
3.7 again.
In that case you have to set to libtiff 4.0.0dev-90 and after that you have to copy again the new GNU make files (v3.81) into the directory
(as you already did according to the wiki)
Maybe we have to make that clearer in the wiki or do changes in
the osgeo4w setup to overcome the complicated and somehow interfering
installation of make3.81 and libtiff 4.0.0dev-90.
/Johannes
-------- Original-Nachricht --------
> Datum: Mon, 28 Nov 2011 17:54:07 +0530
> Von: Sandip Maity <sandip.stesalit at gmail.com>
> An: Johannes Radinger <JRadinger at gmx.at>
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] Runtime error! / Program: C:\\Osgeo4w\\bin\\python.exe
> Dear Johannes,
> I have installed libtiff 4.0.0dev-91 via osgeo4w setup.
> Please suggest the way.
> Regards.
> Sandip
> On Mon, Nov 28, 2011 at 4:42 PM, Johannes Radinger <JRadinger at gmx.at>
> wrote:
> > Hello,
> > after a quick google-search: It seems an Error related to
> > the MSVCR80.DLL. AFAIK this .dll comes
> > with the libtiff via the osgeo4w setup. Which version of
> > libtiff do you have installed (check in the osgeo4w advanced
> > setup)?
> > But maybe some others have any other idea!?
> > /Johannes
> > > Datum: Mon, 28 Nov 2011 15:49:14 +0530
> > > An: grass-user at lists.osgeo.org
> > > Betreff: [GRASS-user] Runtime error! / Program:
> > > Dear friend,
> > > I am compiling and installing grass on windows.
> > > But getting error as follows.
> > > Runtime error!
> > > R6034
> > > An application has made an attempt to load the c runtime library
> > > incorrectly.
> > > Please help me how can i resolve the issues.
> > > regards.
> > > Sandip
> > NEU: FreePhone - 0ct/min Handyspartarif mit Geld-zurück-Garantie!
> > Jetzt informieren: http://www.gmx.net/de/go/freephone
