[GRASS-user] overlapping areas seem valid to v.build: why?
Markus Metz
markus.metz.giswork at googlemail.com
Wed Nov 30 12:37:26 EST 2011
Moritz Lennert wrote:
> On 30/11/11 14:38, Markus Metz wrote:
>> It seems to me that the confusion arises because you made use of
>> features that allow you to skip topological cleaning which is not the
>> default and not recommended.
> Maybe this calls for a v.check.topology module ? Or an option in v.build or
> v.clean which does that (i.e. just check, not clean) ?
Good idea. I would opt for a new option/flag for v.build, which can
already provide rather detailed diagnostics, e.g. dumping topology.
Something like v.build -e for extended topology checks?
Markus M
