[GRASS-user] r.mapcalc appears to have changed behavior
Shane Litherland
litherland-farm at bigpond.com
Mon Oct 3 20:04:44 EDT 2011
Nice to know I can remove one possibility from my list of computing
worries :-)
regards,
shane.
On Sat, 2011-10-01 at 00:51 -0700, Michael Barton wrote:
> Fortunately, upgrading GRASS should have no effect on the region settings for maps.
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Sep 30, 2011, at 11:35 PM, Shane Litherland wrote:
> > Jim, et al.,
> > I am not an authority on GRASS, but it may not have been you that 'did
> > that' - if you were using an earlier version and did a significant
> > upgrade or a fresh install of a newer version of GRASS, some fine
> > details like this might end up with new default values (?) I recall
> > doing a few re-installs/upgrades and having to keep a close eye on user
> > settings, mapset locations, etc when starting up a newer GRASS.
> > May not be what happened in your case, but worth keeping in mind if/when
> > you are moving around GRASS versions or using it on other computers etc,
> > check up on some of the environment variables as you go. Help docs have
> > info on how to find the gory detail :-)
> > From: Jim Mochel <jim.mochel.hivol at gmail.com>
> > Subject: Re: [GRASS-user] r.mapcalc appears to have changed behavior
> > To: Michael Barton <michael.barton at asu.edu>
> > Cc: grass-user grass-user <grass-user at lists.osgeo.org>
> > Message-ID:
> > <CAE=Y9-Tfacpyg_cSaP9w_5U47MdCu_PHuxmaywURw2kEvz0HTw at mail.gmail.com>
> > Content-Type: text/plain; charset="iso-8859-1"
> > Thank you. !
> > I am not sure how I did that but I am sure it seemed like a good idea at
> > the
> > time :-)
> > Jim
