[GRASS-user] What does agnps stand for in r.fill.dir
Rainer M Krug
r.m.krug at gmail.com
Tue Oct 4 04:41:15 EDT 2011
On Mon, Oct 3, 2011 at 4:05 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Sep 30, 2011 at 8:25 PM, Rainer M Krug <r.m.krug at gmail.com> wrote:
> > On Fri, Sep 30, 2011 at 3:48 PM, ahmadou dicko <dicko.ahmadou at gmail.com>
> > wrote:
> >> Hi Rainer,
> >> I think that AGNPS stand for AGricultural Non-Point Source Pollution
> >> Model, more info at : http://go.usa.gov/KFO
> > I found that as well - but the naming does not make that much sense, as
> > agnps stands for a format of the flow direction? I assume, the coding of
> the
> > direction is in line with what the AGNPS model needs.
> You can find (oldish) material about AGNPS here:
> http://grass.osgeo.org/gdp/erosion/agnps/
Thanks - will look at it.
Cheers,
Rainer
> Markus
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111004/d355caff/attachment.html
