[GRASS-user] "Automatic" redraw of map display in 6.4 when
underlying raster changes?
Rainer M Krug
r.m.krug at gmail.com
Thu Oct 6 03:21:15 EDT 2011
On Wed, Oct 5, 2011 at 11:31 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Rainer M Krug wrote:
> > I am looking for a way to automatically redraw a map if the underlying
> > raster map is changing.
> > Background: I am running a spatial simulation, and would like to see open
> a
> > few graphics monitors (or similar)to follow how certain maps are changing
> > over time. Is there a way of doing this?
> > At the moment I am using d.mon and d.rast but these are static and not
> > refresh when the underlying raster is changing. TO make it even more
> > interesting: I am doing some steps of the simulation in R and only write
> the
> > results back to the GRASS database.
> > If it is not possible in 6.x, will it be possible in 7?
> GRASS doesn't have any mechanism to obtain notifications when maps
> change. You will need to have your code provide such notifications.
Thanks - I thought that much, but I wanted to make sure.
As I am scripting GRASS from R, this should not be to difficult - just add
the notifications to the functions which can modify grass layers(execGRASS,
writeRAST6, writeVECT6) and then react on these notifications.
> Monitoring the filesystem is likely to be unreliable, as there's no
> straightforward way to determine when files are in a consistent state.
Thanks for pointing this out and saving me some work - otherwise I might
have chosen that path...
Cheers,
Rainer
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111006/3ce0fc2e/attachment.html
