[GRASS-user] "Automatic" redraw of map display in 6.4 when underlying raster changes?
Rainer M Krug r.m.krug at gmail.com
Fri Oct 7 03:26:14 EDT 2011
On Fri, Oct 7, 2011 at 5:22 AM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Rainer M Krug wrote:
> > > Monitoring the filesystem is likely to be unreliable, as there's no
> > > straightforward way to determine when files are in a consistent state.
> > Thanks for pointing this out and saving me some work - otherwise I might
> > have chosen that path...
> Also, doing this at the library level would have similar issues,
> albeit less severe.
> E.g. when a module finishes writing the actual raster data (i.e.
> G_close_cell() or Rast_close()), often the next thing it does is to
> write metadata (categories, colour table, history). There is no
> specific "event" which signals that the output raster is "complete".
> Generating notifications on "close" operations would ensure that
> individual files are consistent, but that doesn't mean that the raster
> as a whole is consistent.
> This is something that has been discussed in the past, but without
> resolution. Improvements in this area are certainly desirable; e.g.
> reading a map in another mapset relies upon luck, as there is no
> mechanism to ensure that the owner of that mapset isn't modifying the
> map in question at the time. Unfortunately, the issues are complex,
> making it hard to decide what should be done, let alone doing it.
Thanks a lot for all your input - I think I will put in a mechanism in the
model (i.e. writing a file when a layer has been updated ) which I can react
on from an external viewer / application.
Cheers,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax (F):       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111007/4f470a06/attachment.html
