[GRASS-user] Smoothing algorithim to remove small spikes
spiderplant0 spiderplant0 at gmail.com
Sat Oct 8 14:14:08 EDT 2011
Hi, I have a vector map that has some narrow features (boat jettys etc) that
I wish to smooth out. Can anyone suggest a method of achieving this please?
I have tried several of the algorithims in v.generalise without success.
One of the problems I am experiencing is that small details seem to be
treated similarly to large scale detail.
See links to example using snakes method.
Map prior to filtering...
http://osgeo-org.1803224.n2.nabble.com/file/n6873002/grass_test2_input.jpg
Map after filtering...
http://osgeo-org.1803224.n2.nabble.com/file/n6873002/grass_test2_filtered.jpg
Composite map....
http://osgeo-org.1803224.n2.nabble.com/file/n6873002/grass_test2_both.jpg
At the bottom-left of the map I have small spikes that I want smoothed over.
They have been smoothed out reasonably well but the large spike has been
converted into a short fat spike. I.e. it has been reduced in size by around
the same percentage as the small ones. Also at the top-right of the map, a
huge area of land has been chopped off.
Its as if the smoothing algorithm didnt take account of scale but just
consider a number of vertices each side of the point and apply the filter
without considering how far apart in metres the points are.
What I'm looking for is a way to smooth out the small detail especially
small spikes, but not chop out big areas of land at larger scales.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Smoothing-algorithim-to-remove-small-spikes-tp6873002p6873002.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111008/1a68e3c7/attachment.html
