[GRASS-user] RE: reprojection issue, using grass6.2
Duffy, Garret
garret.duffy at nuigalway.ie
Wed Oct 12 09:45:35 EDT 2011
After doing some more investigating, it appears g.proj is not reading
all the parameters in :
proj=omerc +ellps=WGS84 +k_0=1.0 +lat_0=53.25 +no_uoff +rot_conv
+alpha=-88 +lonc=-5.7
For example, the above command projects (-5.7d, 53.25d) correctly to
(X,Y)=(-5901478, 7901021). But after g.proj, the same point projects to
(X,Y)=(0,0).
Can someone help with this?
Thanks,
Garret
Dr. Garret Duffy
______________________
Department of Earth and Ocean Sciences
National University of Ireland, Galway
University Road
Galway
IRELAND
Office: +353 (0)91 492169
Fax: +353 (0)91 750533
> _____________________________________________
> From: Duffy, Garret
> Sent: 12-Oct-11 12:29 PM
> To: 'grass-user at lists.osgeo.org'
> Subject: reprojection issue, using grass6.2
> Hi,
> I have three locations defined, one in Geographic 'projection', one
> UTM and the other described below. When I try to reproject data, e.g.
> a vector rectangle from either Geographic or UTM to the Oblique
> Mercator projection defined below, the rectangle isn't rotated as I
> expect. The origin of the projected coordinates looks to be in the
> correct location but there is no rotation applied (geographic north is
> supposed to ~45 deg from the y axis). BTW, is it even possible to
> display a geodetic grid for a non-rectified projection?
> output from g.proj -p:
> -PROJ_INFO-------------------------------------------------
> proj : omerc
> a : 6378137
> es : 0.006694379990141316
> lat_0 : 53.25
> lonc : -5.7
> alpha : -88
> k : 1
> x_0 : 0
> y_0 : 0
> towgs84 : 0,0,0,0,0,0,0
> no_defs : defined
> -PROJ_UNITS------------------------------------------------
> unit : meter
> units : meters
> meters : 1
> The command I used to specify the oblique projection is:
> proj +proj=omerc +ellps=WGS84 +k_0=1.0 +lat_0=53.25 +no_uoff +rot_conv
> I must emphasize that I have checked the proj.4 parameters using the
> command-line proj.4 and the *parameters are correct*. I applied these
> parameters in GlobalMapper to get the final map to the state that I
> would like eventually in GRASS.
> Any advice would be *greatly* appreciated, I have spent a lot of time
> on this.
> Regards,
> Garret
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111012/c8e3306a/attachment.html
