[GRASS-user] upslope contributing areas
Rainer M Krug
r.m.krug at gmail.com
Thu Oct 13 03:41:31 EDT 2011
On Thu, Oct 13, 2011 at 9:04 AM, Francesco Mirabella <mirabell at unipg.it>wrote:
> Hello,
> and thanks for your fast replies,
> yes, the final result which I'd like to get is a river profile along which
> the values of the upslope contributing areas can be plotted on a separate y
> axis.
> In order to get this I suppose I should be able to "cat
> river_long_profile_ascii | r.profile a_raster_map_containing_the
> upslope_areas" which can provide values in square meters or square km or
> whatever.
> Do you know if such a raster map can be obtained from a dem?
Possibly r.flow could help here - in the manual:
There are three possible output maps which can be produced in any
combination simultaneously: a vector map *flout* of flowlines, a raster map
*lgout* of flowpath lengths, and a raster map *dsout* of flowline densities
(which are equal upslope contributed areas per unit width, when multiplied
by resolution).
If you need it more accurate, maybe use *r.drain for each cell and add* the
flowpaths accordingly.
Cheers,
Rainer
> Francesco
> Rainer M Krug wrote:
>> It depends on what the OP was looking for - it sounds to me that he is
>> looking for a kind of "dynamic" approach, where one can determine the
>> upslope drainage area for an arbitrary location. Unfortunately, I don't have
>> a solution, but would be quite interested in the answer.
>> Cheers,
>> Rainer
>> On Thu, Oct 13, 2011 at 8:36 AM, Johannes Radinger <jradinger at gmx.at<mailto:
>> jradinger at gmx.at>> wrote:
>> Hello Francesco,
>> you could use something like the AddOn r.stream.basin
>> (http://grass.osgeo.org/wiki/**R.stream.*<http://grass.osgeo.org/wiki/R.stream.*>
>> to delineate the basins. Every basin gets a unique number.
>> Afterwards you can just query how
>> many cells do have a certain number.
>> best regards!
>> Am 13.10.2011 <tel:13.10.2011> um 08:20 schrieb Francesco Mirabella:
>> > Hi list,
>> > does anyone know if there is a way to compute the upslope
>> drainage contributing areas along a stream?
>> > thanks for your help!
>> > Francesco
>> > ______________________________**_________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org <mailto:grass-user at lists.**osgeo.org<grass-user at lists.osgeo.org>
>> > http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel : +33 - (0)9 53 10 27 44
>> Cell: +33 - (0)6 85 62 59 98
>> Fax (F): +33 - (0)9 58 10 27 44
>> Fax (D): +49 - (0)3 21 21 25 22 44
>> email: Rainer at krugs.de <mailto:Rainer at krugs.de>
>> Skype: RMkrug
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
South Africa
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111013/4bae9c0a/attachment-0001.html
