[GRASS-user] Linking raster map instead of copying - alternative to
r.reclass?
Rainer M Krug
r.m.krug at gmail.com
Thu Oct 13 03:55:07 EDT 2011
Hi
I want to be able to acess the same raster map by using two different names,
e.g. "map_2007" and "map".
Is there a way of achieving this (under Linux)? I am using r.copy at the
moment, but it uses quite a bit of hdd space (I have many maps!). I could
use r.reclass,
r.reclass input=map_2007 output=map rules=???
but what do I put in ??? Which rules do I use?
but is there an easier way of achieving this?
In addition, would r.reclass be dynamic, i.e. if map_2007 is changing, will
that be reflected when I access map?
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111013/f30d8c82/attachment.html
