[GRASS-user] Two different raster maps with only NULL?
Rainer M Krug
r.m.krug at gmail.com
Thu Oct 13 07:25:19 EDT 2011
Hi
in simulations (R) I create teh following two raster layers (
HSericea_individuals_2006 and HSericea_individuals_2007) and, as you can see
below,
HSericea_individuals_2006 has no range, and HSericea_individuals_2007 has
them. The problem is, that I can not read the HSericea_individuals_2007 into
R. So I have two questions:
1) How can this happen, that the one has range information, the other
doesn't (probably rather an R question...)?
2) How can I delete the range info?
Cheers,
Rainer
GRASS 6.4.1 (grass):~/.../AlienSpread/trunc > r.stats
* 100%
[Raster MASK present]
* 100%
-nan--nan
GRASS 6.4.1 (grass):~/.../AlienSpread/trunc > r.infoHSericea_individuals_2006
| Layer: HSericea_individuals_2006 Date: Thu Oct 13 13:11:03
2011 |
| Mapset: ASM.2006 Login of Creator:
rkrug |
grass |
| DataBase:
/home/rkrug/Documents/ProjectsPartition/AlienSpread/trunc |
| Title: ( HSericea_individuals_2006
| Timestamp:
none |
| Type of Map: raster Number of Categories:
255 |
| Data Type:
FCELL |
| Rows:
520 |
| Columns:
192 |
| Total Cells:
99840 |
| Projection: UTM (zone
-34) |
| N: 6247000 S: 6195000 Res:
100 |
| E: 270200 W: 251000 Res:
100 |
| Range of data: min = -nan max =
-nan |
| Data
Description: |
| generated by
r.in.arc |
Comments: |
| r.in.arc input="./data/input//HSericea_individuals_2006.asc"
output=\ |
| "HSericea_individuals_2006" type="FCELL"
mult=1.0 |
GRASS 6.4.1 (grass):~/.../AlienSpread/trunc > r.infoHSericea_individuals_2007
| Layer: HSericea_individuals_2007 Date: Thu Oct 13 13:15:56
2011 |
| Mapset: ASM Login of Creator:
rkrug |
grass |
| DataBase:
| Title: ( HSericea_individuals_2007
| Timestamp:
none |
255 |
| Data Type:
FCELL |
| Rows:
520 |
| Columns:
192 |
| Total Cells:
99840 |
-34) |
100 |
100 |
| Range of data: min = inf max =
inf |
| Data
Description: |
| generated by
r.in.bin |
Comments: |
| r.in.bin -f
input="/home/rkrug/Documents/ProjectsPartition/AlienSpre\ |
| ad/trunc//grass/ASM/.tmp/ecolmod/X889"
output="HSericea_individuals_\ |
| 2007" bytes=4 north=6247000 south=6195000 east=270200 west=251000
ro\ |
| ws=520 cols=192
anull=NA |
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111013/bc1254d8/attachment.html
