[GRASS-user] Multiple installs of GRASS?
Shane Litherland
litherland-farm at bigpond.com
Thu Oct 13 10:15:01 EDT 2011
Thanks Paulo, I suspected that was the 'right' way to approach it but
was vague on the locations/config.
See how I go with it (a weekend project I think).
-shane.
On Thu, 2011-10-13 at 14:49 +0200, Paulo van Breugel wrote:
> You can compile your ' working' GRASS in e.g., /usr/local/grass64 and
> your 'try-out' GRASS in /usr/local/grass70. You do this setting the
> --prefix option when configuring (e.g., ./configure
> --prefix=/usr/local/grass64 ...).
> To be able to run the working and try-out versions by typing
> respectively grass64 and grass70 on the command line, you copy their
> executables to the /usr/bin, like below;
> ln -s /usr/local/grass64/bin/grass64 /usr/bin/
> ls -s /usr/local/grass70/bin/grass70 /usr/bin/
> Just realized you already have a functional one installed. In that
> case, just install the try-out version as described above, it should
> not interfere with the existing one.
> Cheers,
> Paulo
> On Thu, Oct 13, 2011 at 2:33 PM, Shane Litherland
> <litherland-farm at bigpond.com> wrote:
> Hi all,
> So, I know one can have a 'working' GRASS and a
> 'try-if-you-dare' GRASS
> on the one computer... a quick web search on how to do
> multiple grass
> installs gave me more info on laying turf than on computing
> though!
> The GRASS wiki has good info on compiling from source, but
> didn't see
> anything clear about how to set up a testing GRASS without it
> interfering with my existing, functional one.
> Any tips on where/what to read to get this right? am on ubuntu
> 10.04,
> working with GRASS 6.4.1, want to try the 6.4.2RC to check if
> a few
> glitches I am aware of have been sorted out.
> I probably read info about this months/years ago but need to
> update
> myself before I blunder on into compiling from source-code!
> Regards,
> Shane.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
