[GRASS-user] Linking raster map instead of copying - alternative
to r.reclass?
Rainer M Krug
r.m.krug at gmail.com
Fri Oct 14 09:07:14 EDT 2011
On Fri, Oct 14, 2011 at 3:05 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Rainer M Krug wrote:
> > > > In addition, would r.reclass be dynamic, i.e. if
> > > > map_2007 is changing, will that be reflected when
> > > > I access map?
> > > yes, although only categories present when the
> > > original r.reclass command was run would be
> > > considered. (e.g. if the range expands the reclass
> > > table won't know about that)
> > would this be a problem if I use "* = "?
> Yes. The "*" is expanded when r.reclass is run, not when the reclass
> map is accessed.
OK - so I can't use it.
> > > alternatively, you might try a big pile of symlinks.
> > > (probably much easier for vector maps)
> > I think I'll go that way - I just thought there would be a solution
> > available.
> > So which files would I need to symlink? Asked otherwise: in which
> > directories *can* be raster map related files?
> cellhd, cell, fcell, cats, colr, hist, cell_misc
Thanks - I will then write my own little script.
Cheers,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111014/86591e27/attachment-0001.html
