[GRASS-user] v.in.ogr of a 3d shape
Sebastian Schubert
schubert.seb at googlemail.com
Fri Oct 14 11:09:57 EDT 2011
I want to read a 3d shape. Unfortunately, it does not finish (killed
after 2 hours!). Qgis is able to import it although I guess it is done
in 2d what grass is also capable of without the -z switch. Here is the
output with grass 6.4.1:
> v.in.ogr --v -z dsn=St_Flaeche_3D.shp out=basel3d
Projection of input dataset and current location appear to match
Using temporary vector <basel3d_tmp>
Layer: St_Flaeche_3D
Counting polygons for 1192679 features...
Boundary splitting distance in map units: 176.386
Importing map 1192679 features...
100%
Building topology for vector map <basel3d_tmp>...
Registering primitives...
397678 primitives registered
1549444 vertices registered
Topology was built
Number of nodes: 268594
Number of primitives: 397678
Number of points: 0
Number of lines: 0
Number of boundaries: 397678
Number of centroids: 0
Number of areas: -
Number of isles: -
WARNING: Cleaning polygons, result is not guaranteed!
Break polygons:
100%
100%
Remove duplicates:
100%
Break boundaries:
100%
Intersections: 239035
Remove duplicates:
100%
Clean boundaries at nodes:
Break boundaries:
100%
Intersections: 22
Remove duplicates:
100%
Break boundaries:
100%
Intersections: 0
Remove duplicates:
100%
Change dangles to lines:
100%
Remove bridges:
99%
Here it stops to produce output but still there is 100% CPU usage. Any idea?
Thank you
Sebastian
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20111014/f648a8d8/signature.bin
