[GRASS-user] Envoking GRASS in a python script
kungphil
phil.wilkes at dse.vic.gov.au
Tue Oct 18 02:05:44 EDT 2011
Hello
I am trying to envoke GRASS 6.4.1 from a python(2.6) script on a Solaris 10
OS, I am creating the WIND, PROJ_INFO and PROJ_UNITS from a PSQL database
table and this seems to work fine as it creates a vaible GRASS session. The
next seesion is the part I am havin a problem with, please see script
below...
Import os, sys, psycopg2, getpass, shutil, shlex
user = getpass.getuser()
#Create temporary GRASS directories
tLOCATION = ('/home/syst/' + user + '/tempGRASS')
os.mkdir(tLOCATION)
os.mkdir(tLOCATION + '/PERMANENT')
#CONNECT TO DB
conn = psycopg2.connect("dbname=statewide user=" + user)
cur = conn.cursor()
list = ['WIND', 'PROJ_INFO', 'PROJ_UNITS']
for item in list:
cur.execute('select val from grass_info where file = \'' + item +
sGrassPram = str(cur.fetchall()[0])
sGrassPram =
sGrassPram[sGrassPram.find('(')+2:sGrassPram.find(')')-2]
aFILE = open(tLOCATION + '/PERMANENT/' + item,'w')
for file in str.split(sGrassPram,','):
file = str.strip(file) + '\n'
aFILE.write(file)
aFILE.close()
shutil.copyfile(tLOCATION + '/PERMANENT/WIND', tLOCATION +
'/PERMANENT/DEFAULT_WIND')
#CREATE GRASS RC
aFILE = open(tLOCATION + '/PERMANENT/GRASSRC','w')
aFILE.write('GISDBASE: ' + tLOCATION + '\n')
aFILE.write('LOCATION_NAME: tempGRASS' + '\n')
aFILE.write('MAPSET: PERMANENT')
aFILE.close()
#GRASS environment variables
os.environ['PYTHONPATH'] = '$PYTHONPATH:/opt/isg/grass-6.4.1-64/etc/python'
os.environ['GISBASE'] = '/opt/isg/grass-6.4.1-64'
os.environ['PATH'] = '$PATH:$GISBASE/bin:$GISBASE/scripts'
os.environ['LD_LIBRARY_PATH'] = '$LD_LIBRARY_PATH:$GISBASE/lib'
os.environ['GIS_LOCK'] = '$$'
os.environ['GISRC'] = tLOCATION + '/PERMANENT/GRASSRC'
try:
import grass.script as grass
env = grass.gisenv()
base = env['GISDBASE']
print base
except Exception, err:
print err
Doing this I get an error (with traceback)...
File "/scratch/pw38/sql_py_grass/grass_temp.py", line 44, in <module>
File "/opt/isg/grass-6.4.1-64/etc/python/grass/script/core.py", line 514,
in gisenv
s = read_command("g.gisenv", flags='n')
File "/opt/isg/grass-6.4.1-64/etc/python/grass/script/core.py", line 225,
in read_command
ps = pipe_command(*args, **kwargs)
File "/opt/isg/grass-6.4.1-64/etc/python/grass/script/core.py", line 202,
in pipe_command
return start_command(*args, **kwargs)
File "/opt/isg/grass-6.4.1-64/etc/python/grass/script/core.py", line 164,
in start_command
return Popen(args, **popts)
File "/opt/isg/grass-6.4.1-64/etc/python/grass/script/core.py", line 55,
in __init__
startupinfo, creationflags)
File "/opt/isg/lib/python2.6/subprocess.py", line 621, in __init__
errread, errwrite)
File "/opt/isg/lib/python2.6/subprocess.py", line 1126, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
Any help appreciated
Regards, Phil
As an aside I don't think the os.environ is working correctly, if I comment
out the 'import grass.script as grass' and below and then run the script I
get no error (then get the error above if I include it again), but if I run
the above script in a new shell I get the error...
No module named grass.script
Help with this would also be appreciated or should I start new thread?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Envoking-GRASS-in-a-python-script-tp6903363p6903363.html
Sent from the Grass - Users mailing list archive at Nabble.com.
