[GRASS-user] odd r.stats output, after r.resample.stats
Markus Metz
markus.metz.giswork at googlemail.com
Wed Oct 19 02:55:47 EDT 2011
On Tue, Oct 18, 2011 at 9:31 PM, Kirk Wythers <kirk.wythers at gmail.com> wrote:
> I am trying to aggregate resample a 250 meter resolution raster to 1000m resolution as the most frequently occurring value in the 250m map. I am using:
> GRASS 6.4.1 (northcentralus_albersequalarea):~ > r.resamp.stats -w input=mnwimifnfftgk7wt175v3_250m output=mnwimifnfftgk7wt175v3_1000m method=mode --verbose 100%
> This all appears to work properly. If I export the raster to MATLAB and simply view the cell values they are all whole number like 500, 600, 700, etc....
> However, when I run r.stats on each map, I get:
> GRASS 6.4.1 (northcentralus_albersequalarea):~ > r.stats -cl input=mnwimifnfftgk7wt175v3_250m 100%
> 0 893025
> 100 18419
> 120 34024
> 170 125
> 260 18
> 380 527
> 400 4269
> 500 36610
> 600 163
> 700 12479
> 800 51090
> 900 53455
> 990 5
> 999 527
> * no data 874
> GRASS 6.4.1 (northcentralus_albersequalarea):~ > r.stats -cl input=mnwimifnfftgk7wt175v3_1000m
> 100%
> 0-3.917647 from to 929109
> 97.941176-101.858824 from to 11467
> 117.529412-121.447059 from to 32643
> 168.458824-172.376471 from to 1
> 258.564706-262.482353 from to 1
> 376.094118-380.011765 from to 30
> 399.6-403.517647 from to 383
> 497.541176-501.458824 from to 24231
> 599.4-603.317647 from to 12
> 697.341176-701.258824 from to 2184
> 799.2-803.117647 from to 50355
> 897.141176-901.058824 from to 55190
> 995.082353-999 from to 4
> The output to r.stats from the 250 meter resolution map look fine... but doesn't make sense to me that the 1000 meter resolution map would have it's count and cell values binned into groups like 0-3.9, and 97.9-101.9???
That looks like mnwimifnfftgk7wt175v3_250m is of type CELL and
mnwimifnfftgk7wt175v3_1000m is of type FCELL or DCELL. Try reading
mnwimifnfftgk7wt175v3_1000m as CELL (integer) with
r.stats -cli input=mnwimifnfftgk7wt175v3_1000m
HTH,
Markus M
