[GRASS-user] WPS with GRASS and PyWPS
Saber Razmjooei
razmjooeis at faunalia.co.uk
Wed Oct 26 15:08:52 EDT 2011
Valentin
Many thanks for your feed back.
The DTM is quite old (over 20 years) and very coarse (50 metre..but grass
region setting is I think 100 metre).
The reason you don't see the point is that it doesn't use the point and it
uses another one snapped to the stream (r.watershed output). But we
definitely add something to show the point, either user input or the
snapped one.
In terms of validation, we have Flood Estimation Handbook which
unfortunately is not free and using the same DTM in our WPS. For copyright
reasons there is no vector output from FEH either. So you need to create
screenshots. I don't have a license for it.
There will be more bells and whistles to it (hydrological parameters:
urban extent, main drain slope, max min elevation, etc).
Cheers
Saber
> Nice tool, I like it!
> Three things came up in my mind when I used it.
> 1) After I selected a point and press calculate I couldn't see any more
> the point I selected...
> 2) It seams like there are some wrong calculation. For example for the
> randomly chosen point (527714, 328638). And the catchment border could
> be a little smoother ;)
> 3) I can only select a visual point, it would be nice to select the
> point by coordinates... it would be more useful.
> Did you try to validate your data with a independent dataset? I know
> from France there exists free hydrological surface catchments shapes
> over the whole country maybe it possible to make a validation with
> public DEM-data like SRTM.
> regards Valentin
> On Oct 26, 2011 9:27 AM, "Saber Razmjooei" <razmjooeis at faunalia.co.uk
> <mailto:razmjooeis at faunalia.co.uk>> wrote:
> Dear list
> We have developed a Web Processing service for calculating catchment
> outlines in UK using GRASS and PyWPS:
> http://www.faunalia.co.uk/catchmentfinder
> Any feedback is appreciated.
> Regards
> Saber
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
