[GRASS-user] Is it possible to export a Raster to KML
katrin eggert
katrineggert1980 at gmail.com
Thu Oct 27 14:15:58 EDT 2011
Hi
Thanks for all the feedbacks
I have used it and It's ok but....
THe results are not much different if I use my data in WGS84UTM and
reprojecting to EPSG:4326. Just a slightly difference. Is this expectable
such a slightyly difference? (I'm not an expert in Geo Reference Systems)
Thanks
2011/10/26 Markus Metz <markus.metz.giswork at googlemail.com>
> katrin eggert wrote:
> > Hi
> > Maybe it would be better to explain that in manual entry. Just one more
> > question: what is the EPSG code for that projection?
> http://www.google.com/search?q=google+kml+epsg
> -> 4326
> > Thanks
> > Kat
> > 2011/10/26 Markus Neteler <neteler at osgeo.org>
> >> On Tue, Oct 25, 2011 at 6:32 PM, katrin eggert
> >> <katrineggert1980 at gmail.com> wrote:
> >> > Hello Daniel
> >> > By reading the r.out.kml manual I have a few questions:
> >> > 1- "KML expects data to be in Latitude-Longitude using the WGS84 datum
> >> > and
> >> > EGM96 vertical datum. ".
> >> (see also
> http://en.wikipedia.org/wiki/Keyhole_Markup_Language#Geodetic_reference_systems_in_KML
> >> > My data is in WGS84 UTM 26N. Does this mean that I
> >> > have to create a new location with this information
> >> Yes. you have to reproject the maps.
> >> Markus
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111027/66ce0eed/attachment.html
