[GRASS-user] r.in.gdal/HF2/HFZ problem
Duffy, Garret garret.duffy at nuigalway.ie
Fri Oct 28 11:21:02 EDT 2011
I'm running grass 6.2 and I've updated gdal to version 1.8.1 in order to
import HF2/HFz files into grass
%r.in.gdal -f
Supported Formats:
  XYZ (rw): ASCII Gridded XYZ
  HF2 (rw): HF2/HFZ heightfield raster
  OZI (ro): OZI
So it should work... but:
%r.in.gdal 'input=/path/to/HFZ/5m_irish_sea.HF2' output=test title=test
ERROR 4: `/path/to/HFZ/5m_irish_sea.HF2' not recognised as a supported
file format.
I really don't want to update grass as version 4.7 of proj that grass
6.4 requires doesn't support general RSO projections and I am trying the
reproject the HF2 file into that projection.
Any help would be greatly appreciated.
**Could I use "gdal_translate" to change the HF2 to a TIF and then use
r.in.gdal??**
Garret
Dr. Garret Duffy
______________________
Department of Earth and Ocean Sciences
National University of Ireland, Galway
University Road
Galway
IRELAND
Office:  +353 (0)91 492169
Fax:  +353 (0)91 750533
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111028/a8b67df3/attachment.html
