[GRASS-user] Re: mapset not found: problem with file permissions?
Glynn Clements
glynn at gclements.plus.com
Fri Oct 28 14:56:27 EDT 2011
Damian M wrote:
> As a follow up, this is what the ls -l command produced for that mounted
> Windows share in Ubuntu, mounted as above:
> drwxrwxrwx 1 damian damian 0 2011-10-27 13:39 fer
> The workspace within that directory also shows me as the owner:
> drwxrwxrwx 1 damian damian 0 2011-03-24 11:21 grassWorkspace
In which case: start GRASS using a local database, then (try to)
switch to the remote database with g.mapset, and post any error
messages.
