[GRASS-user] v.rast.stats error
Daniel Victoria
daniel.victoria at gmail.com
Fri Sep 2 21:35:55 EDT 2011
Hi all,
Trying to run v.rast.stats in GRASS 7.0.svn47742M (2011) (Ubuntu
Linux) and I'm getting the following error:
Any clues as to what is going on?
Thanks
Daniel
v.rast.stats map=microregiao at PERMANENT layer=1
raster=sam_cana at PERMANENT column_prefix=cana
File "/home/daniel/grass/grass_trunk/dist.i686-pc-linux-
gnu/scripts/v.rast.stats", line 270, in <module>
main()
gnu/scripts/v.rast.stats", line 86, in main
vector = options['vector']
KeyError: 'vector'
Error in atexit._run_exitfuncs:
File "/usr/lib/python2.6/atexit.py", line 24, in
_run_exitfuncs
func(*targs, **kargs)
gnu/scripts/v.rast.stats", line 65, in cleanup
grass.run_command('g.remove', rast = rastertmp, quiet =
True)
NameError: global name 'rastertmp' is not defined
Error in sys.exitfunc:
_run_exitfuncs
True)
(Fri Sep 2 22:33:08 2011) Command finished (0 sec)
