[GRASS-user] How to remove nonexistent vector map
Aren Cambre
aren at arencambre.com
Sun Sep 4 22:18:15 EDT 2011
I am trying to run *v.in.ogr* against a PostGIS database. The command's
output is:
*ERROR: Vector map <pointdata> already exists*
Yet when I run *g.remove pointdata*, I get:
*Removing raster <pointdata>*
*Raster map <pointdata> not found*
*<pointdata> nothing removed*
But then you may say, "Hey, moron, that's a vector layer! Use the right
command." OK, I ran *g.remove vect=pointdata *and I get:
*Removing vector <pointdata>*
*DBMI-DBF driver error:*
*Unable to open database <cat C:\Users\Aren Cambre\Desktop\DEEM
documents\GRASS\DallasCountyCrashes\Crases2\dbf\> by driver <dbf>*
*Unable open database <cat C:\Users\Aren Cambre\Desktop\DEEM
*Unable to find table <crash> linked to vector map <pointdata>*
*couldn't be removed*
Huh?
Aren
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110904/3868612b/attachment.html
