[GRASS-user] Re: v.in.ogr.qgis error has no details
Aren Cambre
aren at arencambre.com
Wed Sep 7 21:54:47 EDT 2011
I've reported this one as bug http://trac.osgeo.org/grass/ticket/1445.
Aren
On Mon, Sep 5, 2011 at 10:30 AM, Aren Cambre <aren at arencambre.com> wrote:
> So I've narrowed it down a bit more.
> Attached is an Excel spreadsheet showing the data GRASS is trying to insert
> interposed with the actual column information (name, field type, length,
> etc.) in the GRASS DBF. Note that in some cases, the first *'* in a string
> doesn't appear; that's just how Excel somehow works. (*'* means take the
> following text literally, so *'string'* may appear as *string'* in a few
> places.)
> I'm not clear I see anything obscenely wrong, but I did notice a few cases
> where possibly non-numeric stuff, like *18:40:00*, is being entered into a
> field with N type. Is this valid?
> Again, the key problem here is that GRASS is giving me a "Cannot insert new
> row" error, but it gives me no clue of what the actual problem is.
> Aren
> On Sun, Sep 4, 2011 at 10:19 PM, Aren Cambre <aren at arencambre.com> wrote:
>> I reported this as a bug: http://trac.osgeo.org/grass/ticket/1439.
>> It also happens with the standalone copy of GRASS GIS 6.4.1.
>> Aren
>> On Sun, Sep 4, 2011 at 7:47 PM, Aren Cambre <aren at arencambre.com> wrote:
>>> I am running the GRASS 6.4.1 that is bundled with QGIS 1.7.
>>> When I run v.in.ogr.qgis from the UI, I end up with an error. The source
>>> is a QGIS PostGIS layer that is just geometry points.
>>> From the error details, I assume that v.in.ogr.qgis is just a bridge
>>> between QGIS and v.in.ogr as the actual error message is from v.in.ogr.
>>> The command doesn't work, and the error message is unhelpful. Here's the
>>> module's output:
>>> *v.in.ogr -o "dsn=PG:dbname='de' host=localhost port=5432
>>> user='postgres' password='[redacted]' sslmode=disable" "layer=raw.TxDOT
>>> crash" "where="Cnty_ID" = '57'" output=pointdata snap=-1 min_area=0.0001
>>> *Over-riding projection check*
>>> *Layer: raw.TxDOT crash*
>>> *Default driver / database set to:*
>>> *driver: dbf*
>>> *database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/*
>>> *Counting polygons for 264398 features...*
>>> *Importing map 264398 features...*
>>> *DBMI-DBF driver error:*
>>> *Cannot insert new row: insert into pointdata values ( 1, '[redacted--was
>>> a time]', '', 1, NULL, 32.959261, 2, NULL, NULL, NULL, 6, 0, NULL, 'N',
>>> '', NULL, 0, NULL, NULL, NULL, NULL, '', NULL, 0, 2, '762', '', NULL, 0,
>>> NULL, 0, NULL, NULL, NULL, '', 'N', NULL, 0, NULL, 'E BETHEL SCHOOL RD', 8,
>>> NULL, 0, NULL, 4, 38, NULL, NULL, NULL, '', 'N', NULL, NULL, 'N', 1, NULL,
>>> 94, '', NULL, NULL, 8, 22, 22, NULL, NULL, 'N', 'N', '[redacted--was a
>>> date]', NULL, 2, NULL, '', 'N', NULL, NULL, NULL, NULL, NULL, NULL,
>>> NULL, NULL, NULL, NULL, NULL, 0, NULL, 0, 1, 0, 1, NULL, NULL, 5, 'Y', NULL,
>>> NULL, NULL, '', 3, '', NULL, '', 1, 2, NULL, 'N', 'MOCKINGBIRD LN', NULL, 1,
>>> '', 57, NULL, 1, NULL, NULL, 64, 0, 1, NULL, 0, NULL, NULL, NULL, '', 1, 0,
>>> NULL, 'N', NULL, 'N', 0, NULL, 1, NULL, 2003000146, 'Y', '', NULL, 0, NULL,
>>> '', 2, 'Y', -96.968529, 0, 0, NULL )*
>>> *Finished with error*
>>> I have no idea why this insert didn't work; the error has no details.
>>> Searching online, it appears this error message almost always has an
>>> explanation provided by GRASS.
>>> Is there something that is being done to suppress the error details here?
>>> Aren
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110907/8b6985e4/attachment.html
