[GRASS-user] import shpfiles dbmi: Protocol error
Markus Metz markus.metz.giswork at googlemail.com
Thu Sep 8 03:59:28 EDT 2011
On Wed, Sep 7, 2011 at 11:48 PM, Matthew Mulbrandon <mulbran at hotmail.com> wrote:
> More info
> Ubuntu lucid
32 or 64bit?
> grass 6.4.1
32 or 64bit?
Your database connection? db.connect -p
> The actual file can be downloaded at
> http://leegis.leegov.com/GISData.htm
> and the data set is called 'parcel and condo points' about 150 mb.
With dbf as database driver, I get an out-of-memory error on Linux 64
bit 4 GB RAM. With sqlite as database driver it works.
Markus M
> Thanks,
> Matthew
>> Date: Wed, 7 Sep 2011 19:53:08 +0200
>> Subject: Re: [GRASS-user] import shpfiles dbmi: Protocol error
>> From: markus.metz.giswork at googlemail.com
>> To: mulbran at hotmail.com
>> CC: grass-user at lists.osgeo.org
>> On Wed, Sep 7, 2011 at 4:33 PM, Matthew Mulbrandon <mulbran at hotmail.com>
>> wrote:
>> > Hi,
>> > Get nebulous error with data set from lee county. Bot dot data and
>> > parcel
>> > data when importing.
>> > v.in.org dsn="filepath" I don't want to write the whole thing.
>> > "Projection of input dataset and current location appear to match.
>> > output = dfds min_aria=0.0001 snap = -1
>> > Layer: Lee-parcel
>> > Counting polygons for 526085 features
>> > Importing map 526085 features...
>> > dbmi: Protocol error"
>> > This happens about about 75 percent for the point map. 95 percent for
>> > the
>> > parcel map.
>> > I can open the dot file in qgis and the are 0 errors. I can clip and
>> > import
>> > fine into grass.
>> > So I think there might be a null value or maybe some other values that
>> > is
>> > killing the import.
>> > Any help would be appreciated.
>> Can you please provide information about the GRASS version you use,
>> the operating system and which database driver you are using (output
>> of db.connect -p)?
>> Thanks,
>> Markus M
