[GRASS-user] v.mkhexgrid bug
Markus Neteler neteler at osgeo.org
Thu Sep 8 16:59:01 EDT 2011
On Fri, Sep 2, 2011 at 3:21 PM, Andrés Silva <andres.silva.m at gmail.com> wrote:
> Hi, I get the following bug with v.mkhexgrid:
> (Fri Sep  2 10:06:01 2011)
> v.mkhexgrid output=grid regionname=ecosistemas at InnovaTurismo sidelength=500
> Creating GRASS ascii file with hexagons
> v.in.ascii completo.
> Cleaning and building topology
> Importing and linking attributes
> ERROR: Input table <tempgrid4328.csv> not found or not readable
> GRASS_INFO_WARNING(4352,3): Nombre de columna cambiado: 'cat' -> 'cat_'
> ERROR: An error occured renaming attribute table.
> ALTER TABLE .tempgrid4328 RENAME TO grid;
> (Fri Sep  2 10:06:08 2011) Comando finalizado. (7 sec)
> It is possible to fix this?
Likely yes. But could you please post an example using
the North Carolina sample dataset? Then we could try
easily.
Markus
