[GRASS-user] r.fillnulls error
Salvatore Mellino
salvatore.mellino at gmail.com
Fri Sep 9 13:12:17 EDT 2011
I'm trying to use r.fillnulls for a DTM generated importing srtm data , but it does' t work. This is the message:
r.fillnulls --overwrite input=14 a PERMANENT output=14_int
Locating and isolating NULL areas...
syntax error, unexpected '@', expecting ')'
Parse error
ERROR: Raster map <r_fillnulls_49960> not found
ERROR: /Applications/GRASS-6.4.app/Contents/MacOS/scripts/r.fillnulls abandoned. Removing temporary map, restoring user mask if needed:
Removing raster <MASK>
Raster map <MASK> not found
<MASK> nothing removed
Removing raster <r_fillnulls_49960>
<r_fillnulls_49960> nothing removed
Removing raster <r_fillnulls_49960.buf>
Raster map <r_fillnulls_49960.buf> not found
<r_fillnulls_49960.buf> nothing removed
Removing raster <r_fillnulls_49960_filled>
Raster map <r_fillnulls_49960_filled> not found
<r_fillnulls_49960_filled> nothing removed
raster <usermask_mask.49960> not found
(Fri Sep 9 19:08:00 2011) Command finished (0 sec)
