[GRASS-user] simultaneous raster maps export
giannis Nj netsagief at hotmail.com
Fri Sep 23 05:43:21 EDT 2011
Hi Marcus and thanks for the answer,
i tried your tip but this doesn't work for me, because my firstly imported .tiff layers mostly cover one another, they are not just side-by-side, so if i make them one file i won't be able to use them seperately in the covered areas. Also i want to add a .shp file on top of them and export all together in one schema. I don't know if it is clear what i want, but it is very simple in close-source gis. Does anyone has any idea how i can make this happen in open-source or it is not possible yet? My whole thesis collapsed at this point, so any help would be precious! Thanx.
> From: neteler at osgeo.org
> Date: Thu, 22 Sep 2011 08:42:20 +0200
> Subject: Re: [GRASS-user] simultaneous raster maps export
> To: netsagief at hotmail.com
> CC: grass-user at lists.osgeo.org
> 2011/9/21 giannis Nj <netsagief at hotmail.com>:
> > Hi to all,
> > i try to export, together in one file, 2 or 3 raster maps displayed
> > simultaneously in Grass, so they will remain referenced together and
> > furtherly used seperately or together. Does anybody has any idea if this can
> > happen and how (also to which format)?
> You can export the raster maps separately and then merge them into
> a single GeoTIFF file.
> see
> http://gfoss.blogspot.com/2008/06/gdal-raster-data-tips-and-tricks.html
> -> Merge various map/bands into a RGB composite
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110923/d28632c2/attachment.html
