[GRASS-user] help building GRASS 7 svn on MacOSX Lion
William Kyngesburye
woklist at kyngchaos.com
Fri Sep 23 17:19:54 EDT 2011
It looks like a macports problem (maybe homebrew also uses /opt/local?) with their Python. My guess is that their python is 64bit-only, and Grass is trying to run python 32bit because it couldn't find a 64bit wxpython because 64bit wxpython isn't possible in the stable release.
Note that there is no reason to build Gasss itself 32bit when 64bit works just as well, if not better. GRASS and the wxpython GUI are separate processes and don't have to run the same bit mode. I have finally decided that maintaining 32+64bit packages is too much trouble and future frameworks will be 64bit-only.
On Sep 23, 2011, at 2:50 PM, Carlos Grohmann wrote:
> Hi all,
> I'm trying to build GRASS 7 svn on my mac with OSX Lion, but I'm facing some issues.
> I have the frameworks from Kyngschaos installed.
> make runs fine and no errors are detected. Then I run make bindist to create the .pkg.
> After intalling the pkg, I run it and get this:
> GuanoMac:~ guano$ '/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
> Rebuilding Addon HTML manual pages index...
> Rebuilding Addon menu...
> Python 2.7.2 found.
> arch: posix_spawnp: /opt/local/bin/pythonw2.7: Bad CPU type in executable
> logout
> [Process completed]
> This is my configure setup and its output:
> export CFLAGS="-arch i386 -O2"
> export CXXFLAGS="-arch i386"
> export LDFLAGS="-arch i386"
> ./configure \
> --enable-largefile \
> --prefix=/Applications \
> --enable-macosx-app \
> --enable-sysv \
> --without-glw \
> --without-motif \
> --without-cairo \
> --without-geos \
> --with-x \
> --with-x-includes=/usr/X11R6/include \
> --with-x-libraries=/usr/X11R6/lib \
> --with-opengl=aqua \
> --without-odbc \
> --with-cxx \
> --with-freetype \
> --with-freetype-includes=/Library/Frameworks/FreeType.framework/unix/include \
> --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib \
> --with-gdal=/Library/Frameworks/GDAL.framework/Versions/1.8/Programs/gdal-config \
> --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include \
> --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib \
> --with-proj-share=/Library/Frameworks/PROJ.framework/Versions/4.6/unix/share \
> --with-jpeg \
> --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
> --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-tiff \
> --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
> --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
> --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
> --with-sqlite \
> --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib \
> --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include \
> --without-fftw \
> --with-postgres-includes=/usr/local/pgsql/include \
> --with-postgres-libs=/usr/local/pgsql/lib \
> --with-freetype \
> --with-python=/usr/bin/python2.7-config \
> --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.12.0/bin/wx-config \
> --without-readline \
> --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers /Library/Frameworks/Tk.framework/Headers /Library/Frameworks/Tk.framework/PrivateHeaders" \
> --with-tcltk-libs=/usr/local/lib \
> --with-blas \
> --with-lapack \
> --with-blas-includes=/System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/Headers \
> --with-lapack-includes=/System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/Headers \
> checking host system type... i386-apple-darwin11.1.0
> checking for gcc... gcc
> checking whether the C compiler (gcc -arch i386 -O2 -arch i386) works... yes
> checking whether the C compiler (gcc -arch i386 -O2 -arch i386) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether gcc accepts -g... yes
> checking for Cygwin environment... no
> checking for mingw32 environment... no
> checking for executable suffix... no
> checking for full floating-point support... yes
> checking for pwd... /bin/pwd
> checking for source directory... /Users/guano/Documents/installs/grass/grass_trunk
> checking for build directory... /Users/guano/Documents/installs/grass/grass_trunk
> checking for svnversion... /usr/bin/svnversion
> checking for MacOSX App... yes
> checking for MacOSX architectures... no
> checking for MacOSX SDK... no
> checking how to build libraries... shared
> checking for additional include dirs...
> checking for additional library dirs...
> checking for a BSD compatible install... /usr/bin/install -c
> checking for flex... flex
> checking for yywrap in -lfl... yes
> checking for bison... bison -y
> checking for ranlib... ranlib
> checking for ar... ar
> checking for env... env
> checking for perl... /opt/local/bin/perl
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for limits.h... yes
> checking for termio.h... no
> checking for termios.h... yes
> checking for unistd.h... yes
> checking for values.h... no
> checking for f2c.h... no
> checking for g2c.h... no
> checking for sys/ioctl.h... yes
> checking for sys/mtio.h... no
> checking for sys/resource.h... yes
> checking for sys/time.h... yes
> checking for sys/timeb.h... yes
> checking for sys/types.h... yes
> checking for sys/utsname.h... yes
> checking for libintl.h... no
> checking for iconv.h... yes
> checking for langinfo.h... yes
> checking whether time.h and sys/time.h may both be included... yes
> checking for off_t... yes
> checking for uid_t in sys/types.h... yes
> checking return type of signal handlers... void
> checking for ftime... yes
> checking for gethostname... yes
> checking for gettimeofday... yes
> checking for lseek... yes
> checking for nice... yes
> checking for time... yes
> checking for uname... yes
> checking for seteuid... yes
> checking for setpriority... yes
> checking for setreuid... yes
> checking for setruid... yes
> checking for drand48... yes
> checking for putenv... yes
> checking for setenv... yes
> checking for nanosleep... yes
> checking whether setpgrp takes no argument... yes
> checking for long long int... yes
> checking for W11... no
> checking for X... no
> checking for library containing cuserid... no
> checking for xdrmem_create... yes
> checking for asprintf... yes
> checking for atan... yes
> checking for dlsym... yes
> checking for iconv... no
> checking for iconv in -liconv... yes
> checking for socket... yes
> checking for location of zlib includes...
> checking for zlib.h... yes
> checking for location of zlib library...
> checking for deflate in -lz... yes
> checking for location of External PROJ.4 includes... /Library/Frameworks/PROJ.framework/unix/include
> checking for proj_api.h... yes
> checking External PROJ.4 version... 470
> checking for location of External PROJ.4 library... /Library/Frameworks/PROJ.framework/unix/lib
> checking for pj_get_def in -lproj... yes
> checking for location of External PROJ.4 data files... /Library/Frameworks/PROJ.framework/Versions/4.6/unix/share
> checking for /Library/Frameworks/PROJ.framework/Versions/4.6/unix/share/epsg... no
> configure: warning: *** Unable to locate PROJ data files.
> checking for nad2bin... /opt/local/bin/nad2bin
> checking whether to use regex... yes
> checking for location of regex includes...
> checking for regex.h... yes
> checking for location of regex library...
> checking for regcomp... yes
> checking whether to use Readline... no
> checking whether to use JPEG... yes
> checking for location of JPEG includes... /Library/Frameworks/UnixImageIO.framework/unix/include
> checking for jpeglib.h... yes
> checking for location of JPEG library... /Library/Frameworks/UnixImageIO.framework/unix/lib
> checking for jpeg_start_compress in -ljpeg... yes
> checking whether to use GDAL... yes
> checking for gdal-config... /Library/Frameworks/GDAL.framework/Versions/1.8/Programs/gdal-config
> checking whether to use libLAS... no
> checking whether to use GEOS... no
> checking whether to use TIFF... yes
> checking for location of TIFF includes... /Library/Frameworks/UnixImageIO.framework/unix/include
> checking for tiffio.h... yes
> checking for location of TIFF library... /Library/Frameworks/UnixImageIO.framework/unix/lib
> checking for TIFFOpen in -ltiff... yes
> checking whether to use PNG... yes
> checking for location of PNG includes... /Library/Frameworks/UnixImageIO.framework/unix/include
> checking for png.h... yes
> checking for location of PNG library... /Library/Frameworks/UnixImageIO.framework/unix/lib
> checking for png_read_image in -lpng... yes
> checking whether to use PostgreSQL... no
> checking whether to use MySQL... no
> checking whether to use SQLite... yes
> checking for location of SQLite includes... /Library/Frameworks/SQLite3.framework/unix/include
> checking for sqlite3.h... yes
> checking for location of SQLite library... /Library/Frameworks/SQLite3.framework/unix/lib
> checking for sqlite3_open in -lsqlite3... yes
> checking whether to use FFMPEG... no
> checking whether to use OpenGL... aqua
> checking for location of OpenGL framework...
> checking for OpenGL/gl.h... yes
> checking for OpenGL/glu.h... yes
> checking for glBegin... yes
> checking for gluBeginCurve... yes
> checking whether to use Tcl/Tk... yes
> checking for location of Tcl/Tk includes... /Library/Frameworks/Tcl.framework/Headers /Library/Frameworks/Tk.framework/Headers /Library/Frameworks/Tk.framework/PrivateHeaders
> checking for tcl.h... yes
> checking for tk.h... yes
> checking Tcl version... 8.5
> checking Tk version... 8.5
> checking for location of Tcl/Tk library... /usr/local/lib
> checking for Tcl_Init in -ltcl... yes
> checking for Tk_MainWindow in -ltk... yes
> checking whether to use ODBC... no
> checking whether to use FFTW... no
> checking whether to use BLAS... yes
> checking for location of BLAS includes... /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/Headers
> checking for location of BLAS library...
> checking for cblas.h... yes
> checking for dnrm2_ in -lblas... yes
> checking for ATL_xerbla in -latlas... no
> checking for sgemm in -framework vecLib... no
> checking for sgemm_ in -lblas... yes
> checking for dgemm_ in -ldgemm... no
> checking whether to use LAPACK... yes
> checking for location of LAPACK includes... /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/Headers
> checking for location of LAPACK library...
> checking for clapack.h... yes
> checking for dsegv_... no
> checking for desgv_ in -llapack... no
> checking for dgesv_ in -llapack... yes
> checking whether to use Cairo... no
> checking whether to use FreeType... yes
> checking for location of FreeType includes... /Library/Frameworks/FreeType.framework/unix/include
> checking for ft2build.h... yes
> checking for location of FreeType library... /Library/Frameworks/FreeType.framework/unix/lib
> checking for FT_Init_FreeType in -lfreetype... yes
> checking whether to use NLS... no
> checking whether to use C++... yes
> checking for c++... c++
> checking whether the C++ compiler (c++ -arch i386 -arch i386 ) works... yes
> checking whether the C++ compiler (c++ -arch i386 -arch i386 ) is a cross-compiler... no
> checking whether we are using GNU C++... yes
> checking whether c++ accepts -g... yes
> checking whether to use openDWG... no
> checking whether to use POSIX threads... no
> checking for special C compiler options needed for large files... no
> checking for _FILE_OFFSET_BITS value needed for large files... no
> checking for _LARGE_FILES value needed for large files... no
> checking for _LARGEFILE_SOURCE value needed for large files... no
> checking for fseeko... yes
> checking if system supports Large Files at all... yes
> checking whether to use wxWidgets... yes
> checking for wx-config... /usr/local/lib/wxPython-unicode-2.8.12.0/bin/wx-config
> checking wxWidgets version... 2.8.12
> checking for wx/wxprec.h... yes
> creating ./config.status
> creating include/Make/Platform.make
> creating include/Make/Doxyfile_arch_html
> creating include/Make/Doxyfile_arch_latex
> creating include/version.h
> creating grass.pc
> creating include/config.h
> include/config.h is unchanged
> Copying config.status to config.status.i386-apple-darwin11.1.0
> GRASS is now configured for: i386-apple-darwin11.1.0
> Source directory: /Users/guano/Documents/installs/grass/grass_trunk
> Build directory: /Users/guano/Documents/installs/grass/grass_trunk
> Installation directory: ${prefix}/GRASS-7.0.app/Contents/MacOS
> Startup script in directory: ${exec_prefix}/bin
> C compiler: gcc -arch i386 -O2
> C++ compiler: c++ -arch i386
> Building shared libraries: yes
> 64bit support:
> OpenGL platform: Aqua
> MacOSX application: yes
> MacOSX architectures:
> MacOSX SDK:
> Tcl/Tk NVIZ: yes
> BLAS support: yes
> C++ support: yes
> Cairo support: no
> DWG support: no
> FFMPEG support: no
> FFTW support: no
> FreeType support: yes
> GDAL support: yes
> GEOS support: no
> JPEG support: yes
> LAPACK support: yes
> Large File support (LFS): yes
> libLAS support: no
> MySQL support: no
> NLS support: no
> ODBC support: no
> OGR support: yes
> OpenGL support: yes
> PNG support: yes
> PostgreSQL support: no
> Readline support: no
> SQLite support: yes
> Tcl/Tk support: yes
> wxWidgets support: yes
> TIFF support: yes
> X11 support: no
> Regex support: yes
> POSIX thread support: no
> GuanoMac:grass_trunk guano$
> thanks,
> Prof. Carlos Henrique Grohmann - Geologist D.Sc.
> Institute of Geosciences - Univ. of São Paulo, Brazil
> http://www.igc.usp.br/pessoais/guano
> http://digitalelevation.wordpress.com/
> http://lattes.cnpq.br/5846052449613692 (CV)
> Twitter: @CarlosGrohmann
> http://carlosgrohmann.tumblr.com/
> Linux User #89721
> ________________
> Can’t stop the signal.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
