[GRASS-user] Adding a point vector
Martin Landa
landa.martin at gmail.com
Sat Sep 24 06:37:39 EDT 2011
2011/9/24 Martin Landa <landa.martin at gmail.com>:
>> Okay, I got the point to appear in the right spot. However it doesn't appear in the sqlite data base. I also wanted to add it's attributes. I take it that it isn't as easy as simply filling them in with Sqlite browser.
> `v.edit` doesn't modify attribute table, you can add new record using
> wxGUI Attribute Manager [1].
I added FAQ article to the wiki, I hope it helps
http://grass.osgeo.org/wiki/Add_point_to_vector_map_at_given_position
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
