[GRASS-user] simultaneous raster maps export
giannis Nj
netsagief at hotmail.com
Mon Sep 26 05:47:27 EDT 2011
Hi again!
My input maps (two .tiff and one .shp) makes a pile, they cover each other looking from upside, when i put them in the display i can see them only with transparency. What I want is to export them all together in one file (so that they can keep their reference between them) in an appropriate format so as to insert them in a 3D edit program (with no reference system, thats why i want to export them all together and not one by one) and use them seperately (that's why r.patch can't be useful). Imagine that you look the output file from the side, you see 3 different layers (the top, the middle and the lower) that you can use furtherly (p.e. give them volumes). I think it is a bit challenge!
> From: neteler at osgeo.org
> Date: Sat, 24 Sep 2011 11:55:34 +0200
> Subject: Re: [GRASS-user] simultaneous raster maps export
> To: netsagief at hotmail.com
> CC: grass-user at lists.osgeo.org
> 2011/9/23 giannis Nj <netsagief at hotmail.com>:
> > Hi Marcus and thanks for the answer,
> > i tried your tip but this doesn't work for me, because my firstly imported
> > .tiff layers mostly cover one another, they are not just side-by-side,
> Ah, I understood you wanted a *stack* of maps.
> > so if
> > i make them one file i won't be able to use them seperately in the covered
> > areas.
> So the input maps are side by side? Then you want to mosaik them
> with r.patch.
> > Also i want to add a .shp file on top of them and export all together
> > in one schema. I don't know if it is clear what i want,
> Not much, say, I don't know what a "schema" means.
> > but it is very simple in close-source gis.
> Like so in open source GIS once we know what you wish :)
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110926/9ab5abd3/attachment.html
