[GRASS-user] Re: Cannot create dbf database
Martin Landa landa.martin at gmail.com
Mon Sep 26 14:06:49 EDT 2011
2011/9/26 Craig Leat <craig.leat at gmail.com>:
> GRASS 6.4.1 (wgs84lo29):~ > v.db.connect -p contours2
> Vector map <contours2 at lotheni> is connected by:
> layer <1> table <lo29> in database <cat
> /home/craig/GIS/grassdata/wgs84lo29/lotheni/dbf/> through driver <dbf>
> with key <contours2>
it's absolutely wrong, it should have been
> layer <1> table <contour2> in database </home/craig/GIS/grassdata/wgs84lo29/lotheni/dbf/> through driver <dbf>
> with key <cat>
No idea, why it's wrong. Can you try 6.4.2 from SVN?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
