[GRASS-user] r.mapcalc appears to have changed behavior
Jim Mochel
jim.mochel.hivol at gmail.com
Mon Sep 26 23:19:11 EDT 2011
I had made a number of scripts that worked fine in the 6.4.0 build 6 but
appear to have problems with the same code in later revisions:
The method used to take about 6-8 secs and produce about what you would
expect on the screen. Now the same calculation takes 0 seconds the file is
radically changed. See the before and after below.
Any help would be greatly appreciated.
Thanks
Jim Mochel
r.mapcalc na_dem_sub_20 = na_dem_input - 20
| Layer: na_dem Date: Sat Sep 24 17:37:59 2011
| Mapset: PERMANENT Login of Creator: jmochel
| DataBase: /home/jmochel/grassdata
| Title: ( na_dem )
| Timestamp: none
| Type of Map: raster Number of Categories: 65535
| Data Type: CELL
| Rows: 8384
| Columns: 9102
| Total Cells: 76311168
| Projection: x,y
| N: 4384500 S: -3999500 Res: 1000
| E: 4639500 W: -4462500 Res: 1000
| Range of data: min = 0 max = 65535
| Data Description:
| generated by r.in.gdal
| Comments:
| r.in.gdal input="/home/jmochel/gis/raw-data/hydo1k/na_dem.bil" outpu\
| t="na_dem"
r.info map=na_dem_sub_20
| Layer: na_dem_sub_20 Date: Mon Sep 26 23:06:03 2011
| Title: ( na_dem_sub_20 )
| Timestamp: none
| Type of Map: raster Number of Categories: 610
| Data Type: CELL
| Rows: 1
| Columns: 1
| Total Cells: 1
| Projection: x,y
| N: 1 S: 0 Res: 1
| E: 1 W: 0 Res: 1
| Range of data: min = 610 max = 610
| Data Description:
| generated by r.mapcalc
| Comments:
| na_dem_input at PERMANENT - 20
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110926/e90ff820/attachment-0001.html
