[GRASS-user] r.mapcalc appears to have changed behavior
Michael Barton
michael.barton at asu.edu
Tue Sep 27 01:02:50 EDT 2011
It looks like for the 2nd calculation, your computational region is set to extents of 0W - 1E, 0S - 1N, with a resolution of 1.
So r.mapcalc is only operating on a single 1x1 cell that is outside the area of your raster map.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sep 27, 2011, at 11:50 PM, <grass-user-request at lists.osgeo.org> <grass-user-request at lists.osgeo.org> wrote:
> Date: Mon, 26 Sep 2011 23:19:11 -0400
> From: Jim Mochel <jim.mochel.hivol at gmail.com>
> Subject: [GRASS-user] r.mapcalc appears to have changed behavior
> To: grass-user at lists.osgeo.org
> Message-ID:
> <CAE=Y9-Q7tFZ=cJ4TC6nceYA5B=R9E7RRwZbVfF_fYbMNTEpC6A at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> I had made a number of scripts that worked fine in the 6.4.0 build 6 but
> appear to have problems with the same code in later revisions:
> The method used to take about 6-8 secs and produce about what you would
> expect on the screen. Now the same calculation takes 0 seconds the file is
> radically changed. See the before and after below.
> Any help would be greatly appreciated.
> Thanks
> Jim Mochel
> r.mapcalc na_dem_sub_20 = na_dem_input - 20
> | Layer: na_dem Date: Sat Sep 24 17:37:59 2011
> | Mapset: PERMANENT Login of Creator: jmochel
> | Location: wgs84
> | DataBase: /home/jmochel/grassdata
> | Title: ( na_dem )
> | Timestamp: none
> | Type of Map: raster Number of Categories: 65535
> | Data Type: CELL
> | Rows: 8384
> | Columns: 9102
> | Total Cells: 76311168
> | Projection: x,y
> | N: 4384500 S: -3999500 Res: 1000
> | E: 4639500 W: -4462500 Res: 1000
> | Range of data: min = 0 max = 65535
> | Data Description:
> | generated by r.in.gdal
> | Comments:
> | r.in.gdal input="/home/jmochel/gis/raw-data/hydo1k/na_dem.bil" outpu\
> | t="na_dem"
> r.info map=na_dem_sub_20
> | Layer: na_dem_sub_20 Date: Mon Sep 26 23:06:03 2011
> | Location: wgs84
> | Title: ( na_dem_sub_20 )
> | Timestamp: none
> | Type of Map: raster Number of Categories: 610
> | Data Type: CELL
> | Rows: 1
> | Columns: 1
> | Total Cells: 1
> | Projection: x,y
> | N: 1 S: 0 Res: 1
> | E: 1 W: 0 Res: 1
> | Range of data: min = 610 max = 610
> | Data Description:
> | generated by r.mapcalc
> | Comments:
> | na_dem_input at PERMANENT - 20
