[GRASS-user] Re: Cannot create dbf database
Craig Leat craig.leat at gmail.com
Tue Sep 27 02:16:00 EDT 2011
Hamish wrote:
>> GRASS 6.4.1 (wgs84lo29):~ > v.in.ogr -e dsn="contours lo29.shp" out=contours2
> shapfiles don't like spaces in their names. rename the file(s) to make
> them sql compliant.
Thanks for this. The table is created correctly if I remove the space
from the shapefile name. Maybe v.in.ogr could issue a warning if it
encounters spaces?
Craig
