[GRASS-user] Import a catalog of ascii *.arc files and merge
to a raster
Lars Forseth
lars.forseth at ntebb.no
Sun Apr 1 13:33:15 EDT 2012
Hi!
In help for r.patch I found this:
MAPS=`g.mlist type=rast sep=, pat="map_*"`
g.region rast=$MAPS
r.patch in=$MAPS out=mosaic
That worked for me now.
I importet all files in the catalog by defining import source in the gui
for r.in.gdal as directory; choosing the right directory; and it then
imported all the files, giving them a "prefix" of x2; or some such.
I shall try Markus suggestions next!
regards; and thanks!
larsf
Den 01. april 2012 18:42, skrev Markus Metz:
> Lars Forseth wrote:
>> Thanks Daniel.
>> But no, I was not able to make your suggestion work; it complains that it
>> dos not know the command 'For'...
> In Linux shell and msys this must be lowercase, i.e.
> for i in *.arc
> do r.in.arc $i<output name here>
> done
> or
> for i in *.arc
> do r.in.arc in=$i out=`basename $i .arc`
> done
> followed by something like
> raster_list=`g.mlist type=rast pat=<insert search pattern here> sep=comma`
> g.region -p rast=$raster_list
> r.patch in=$raster_list out=<output name here>
> HTH,
> Markus M
>> Regards larsf
>> Den 01. april 2012 16:01, skrev Daniel Victoria:
>> I believe there is a batch import function in the gui ( I'm not in front of
>> my computer now). If not, you can write a for loop in the command line to
>> import all files.
>> In Linux shell it's something like
>> For i in *.arc
>> Do r.in.arc $i<output name here>
>> Done
>> Daniel
>> On Apr 1, 2012 10:13 AM, "Lars Forseth"<lars.forseth at ntebb.no> wrote:
>>> Hi!
>>> I want to import a set (20) of ESRI ASCII raster files in a catalog, and
>>> merge them to a single GRASS raster dataset.
>>> How do I do that? (Yes I can import each file, and then merge (r.patch),
>>> but..)
>>> Regards larsf
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
