[GRASS-user] Re: r.stream.extract Syntax Problem
Helmut Kudrnovsky
hellik at web.de
Sat Apr 7 15:50:24 EDT 2012
> Each of my two current projects requiring spatial analyses involve
>multiple 12-digit HUC basins (sub-watersheds). I need to separately analyze
>each sub-watershed to determine differences. I can clip vector maps by
>interescting the lines and the sub-watershed boundaries. But, my
>understanding is that raster maps cannot be subdivided in the same way so
>we need to generate masks for the areas to be included in each analysis.
>That is, r.* modules are applied to only those portions of the overall DEM
>map within the mask.
> If there is a module, or process (perhaps applying r.mapcalc for the map
>algebra), that will allow me to create separate DEMs for each sub-watershed
>(or other analytical unit) I would prefer to work with each of those rather
>than need to run r.mask for each different basin. I'd like to learn how to
>sub-set raster DEMs so each basin is a separate map rather than a masked
>portion.
if the (sub-)watershed are already given, maybe the easiest way to define
the region extent for raster processing of your interest is using g.region
[1]:
'g.region -a rast=yourdem align=yourdem vect=subbasin1'
raster processing
'g.region -a rast=yourdem align=yourdem vect=subbasin2'
raster processing
etc.
no need to create separate DEMs for each sub-watershed (or other analytical
units) or masks.
Helmut
[1] http://grass.osgeo.org/grass64/manuals/html64_user/g.region.html
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-stream-extract-Syntax-Problem-tp4690890p4695975.html
Sent from the Grass - Users mailing list archive at Nabble.com.
