[GRASS-user] Unable to select EPSG code for location
RichardC
richtcooper at hotmail.com
Mon Apr 9 04:00:49 EDT 2012
After installing 6.4.2 from source, attempting to insert a spatial reference
system for a new location (/Select EPSG code for spatial reference system/)
was giving an error that it was unable to find EPSG codes at
/usr/local/share/proj/epsg
The configuration commands (--with-proj-share="/usr/share/proj/" ) did not
seem to make a difference?
My solution was to copy the proj directory and contents from /usr/share/proj
to to /usr/local/share
sudo cp -r /usr/share/proj /usr/local/share/
Has anyone else encountered this problem, or perhaps my configuration
options below need amending?
./configure \
--enable-debug \
--enable-largefile \
--with-libs=/usr/lib64 \
--with-geos=/usr/bin/geos-config/ \
--with-cxx \
--with-readline \
--with-freetype=yes \
--with-freetype-includes="/usr/include/freetype2/" \
--enable-largefile=yes \
--with-geos=yes \
--with-cairo \
--with-tcltk-includes="/usr/include/tcl8.5/" \
--with-wxwidgets \
--with-postgres=yes \
--with-postgres-includes="/usr/include/postgresql/" \
--with-sqlite=yes \
--with-python=yes \
--with-opengl-libs="/usr/include/GL" \
--with-ffmpeg=yes \
--with-ffmpeg-includes="/usr/include/libavcodec /usr/include/libavformat
/usr/include/libswscale" \
--with-lapack=yes \
--with-nls=yes \
--with-motif=yes \
--with-readline=yes \
--with-python=yes \
--with-proj-share="/usr/share/proj/" \
Cheers,
Richard
View this message in context: http://osgeo-org.1560.n6.nabble.com/Unable-to-select-EPSG-code-for-location-tp4715353p4715353.html
Sent from the Grass - Users mailing list archive at Nabble.com.
