[GRASS-user] r.stream.extract Syntax Problem
Rich Shepard
rshepard at appl-ecosys.com
Mon Apr 9 16:17:56 EDT 2012
On Sat, 7 Apr 2012, Micha Silver wrote:
> Maybe the MASK is somehow interfereing ??
Micha,
This is apparently not the issue. I followed Helmut's suggestion and set
the proessing region using the vector boundary of one subbasin. Still the
same error: accumulation map does not match elevation map.
What would be very helpful in fixing this mis-match is understanding in
what way the accumulation map does not match the elevation map. Is it the
region (set to the elevation map) or some other parameter?
Rich
