[GRASS-user] Simultaneous r.horizon processes
    Collin Bode
    collin at berkeley.edu
    Wed Apr 18 00:54:27 EDT 2012
Daniel,
Your post prompted me to go back and retest the broken code I had for r.horizon.  I have fixed it and have attached a script that I think is somewhat general, unlike the previous one.
There are several more issues I should mention:
1. Each process MUST run in its own mapset.    Grass mapsets are not thread or process safe.   The multiple instances will overwrite each other and create jibberish.
2. Use python scripts outside of grass so you can define the mapset when you create a separate process.
3. Manually spawn only enough processes as you have CPU cores available.  After that, force your code to wait until that batch is completed.  Once that set is done, spawn the next set.   I did _not_ do this in the code I posted earlier.
Multiprocessing with grass requires a lot of careful hand-holding to make it work.
hopefully the following script is useful.
Collin Bode
Project Manager, Desktop Watershed Integrated Program
National Center for Earth-surface Dynamics
University of California, Berkeley
Cell: 415-305-5346	Lab: 510-643-9294
http://www.nced.umn.edu
http://angelo.berkeley.edu
http://ncalm.berkeley.edu
On Apr 17, 2012, at 12:21 PM, Collin Bode wrote:
> Lee,
> I tried the same thing, trying to integrate a full workflow in Python for r.sun (see attached code).   I am using a 2x2 meter lidar elevation map with about 120 million cells, so automation is pretty necessary.  The whole thing takes 3 weeks to run using 8 CPU cores and 12GB ram.
> However, r.horizon does not work properly on Grass 6.4.2.   I can only get it to run on one core in sequence.  I cannot get it to accept a single angle and run properly.   The output is always for angle 0, both in name and output data.  Bug?   I was planning to post this to the dev list if no one responds here.
> It would be worthwhile to find out if your version is simply overwriting the previous, similarly named map.   If it is, and the maps are actually different (r.info), then you can change your code to run r.horizon for a single angle, then rename the map.   Something like this:
>        for azimuth in range(0,361,step_size):
>                grass.run_command("r.horizon", elevin=dem, \
>                                  direction=angle, maxdistance=maxdistance, \
>                                  horizon=prefhor, dist=dist, overwrite = 1)
>                az = str(azimuth).zfill(3)
>                tempmap = prefhor+'_0'
>                horizonmap = prefhor+'_'+az
>                cmd = tempmap+","+horizonmap
>                grass.run_command("g.rename",rast=cmd)
> r.sun does work in multiple cores.
> Collin Bode
> http://ib.berkeley.edu/labs/power
> <2_rsun_mp.py>
> On Apr 1, 2012, at 5:10 AM, Daniel Lee wrote:
>> Hi list,
>> I've got a large area I'm running r.horizon on. Since the process takes quite a while but it only runs on one processor core and I've got plenty of RAM, I've decided to script it in Python and use run_command and start_command in order to create multiple horizon maps in parallel. Another reason I'm doing it that way is that I only need certain horizons, so I don't want GRASS to do all 360°.
>> The problem is, when I run the script, all of the maps that I want made seem to be made and I can see in top that there are several instances of r.horizon. But only the instance to be finished last is actually saved. Here's the output:
>> Calculating map 1 of 1 (angle 0.000000, raster map <horizon0_0>)
>>  100%
>> Calculating map 1 of 1 (angle 12.500000, raster map <horizon12.5_0>)
>> Calculating map 1 of 1 (angle 7.500000, raster map <horizon7.5_0>)
>> Calculating map 1 of 1 (angle 42.500000, raster map <horizon42.5_0>)
>> Calculating map 1 of 1 (angle 150.000000, raster map <horizon150.0_0>)
>>  100%
>> Calculating map 1 of 1 (angle 162.500000, raster map <horizon162.5_0>)
>>  100%
>> Calculating map 1 of 1 (angle 175.000000, raster map <horizon175.0_0>)
>> Calculating map 1 of 1 (angle 167.500000, raster map <horizon167.5_0>)
>> Calculating map 1 of 1 (angle 197.500000, raster map <horizon197.5_0>)
>> Calculating map 1 of 1 (angle 205.000000, raster map <horizon205.0_0>)
>> Calculating map 1 of 1 (angle 225.000000, raster map <horizon225.0_0>)
>>  100%
>> Calculating map 1 of 1 (angle 257.500000, raster map <horizon257.5_0>)
>> Calculating map 1 of 1 (angle 262.500000, raster map <horizon262.5_0>)
>>  100%
>> Calculating map 1 of 1 (angle 275.000000, raster map <horizon275.0_0>)
>>  100%
>> Calculating map 1 of 1 (angle 295.000000, raster map <horizon295.0_0>)
>> Calculating map 1 of 1 (angle 300.000000, raster map <horizon300.0_0>)
>>  100%
>> Calculating map 1 of 1 (angle 322.500000, raster map <horizon322.5_0>)
>> Calculating map 1 of 1 (angle 325.000000, raster map <horizon325.0_0>)
>>  100%
>> Calculating map 1 of 1 (angle 337.500000, raster map <horizon337.5_0>)
>> Calculating map 1 of 1 (angle 335.000000, raster map <horizon335.0_0>)
>> Calculating map 1 of 1 (angle 345.000000, raster map <horizon345.0_0>)
>> Calculating map 1 of 1 (angle 350.000000, raster map <horizon350.0_0>)
>>  100%
>> Calculating map 1 of 1 (angle 352.500000, raster map <horizon352.5_0>)
>>  100%
>> Calculating map 1 of 1 (angle 355.000000, raster map <horizon355.0_0>)
>>  100%
>> Calculating map 1 of 1 (angle 357.500000, raster map <horizon357.5_0>)
>>  100%
>>  100%
>>  100%
>>  100%
>>  100%
>>  100%
>>  100%
>>  100%
>>  100%
>> But when I do g.list rast at the end of it all I only have these maps:
>> raster files available in mapset <Cloppenburg>:
>> dom_aspect      horizon162.5_0  horizon325.0_0
>> dom_complete    horizon225.0_0  horizon350.0_0
>> dom_slope       horizon262.5_0  horizon352.5_0
>> horizon0_0      horizon275.0_0  horizon355.0_0
>> horizon150.0_0  horizon300.0_0  horizon357.5_0
>> As you can see, the only horizon maps saved are the last ones made. Does anybody know why this is the case and, if so, what would be a good workaround? Finding the horizons serially on only one processor means that my computer does a lot of sitting around twiddling thumbs. Thanks a bunch!
>> Daniel
>> B.Sc. Daniel Lee
>> Geschäftsführung für Forschung und Entwicklung
>> ISIS - International Solar Information Solutions GbR
>> Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
>> Deutschhausstr. 10
>> 35037 Marburg
>> Festnetz: +49 6421 379 6256
>> Mobil: +49 176 6127 7269
>> E-Mail: Lee at isi-solutions.org
>> Web: http://www.isi-solutions.org
>> ISIS wird gefördert durch die Bundesrepublik Deutschland, Zuwendungsgeber: Bundesministerium für Wirtschaft und Technologie aufgrund eines Beschlusses des Deutschen Bundestages, sowie durch die Europäische Union, Zuwendungsgeber: Europäischer Sozialfonds.
>> Zusätzliche Unterstützung erhält ISIS von dem Entrepreneurship Cluster Mittelhessen, der Universität Marburg, dem Laboratory for Climatology and Remote Sensing und dem GIS-Lab Marburg.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Skipped content of type multipart/mixed
