[GRASS-user] Simultaneous r.horizon processes
Daniel Lee
lee at isi-solutions.org
Wed Apr 18 14:44:18 EDT 2012
Hi Collin, Markus,
Thanks a lot for the script and tips, I really appreciate it. That's
definitely a much bigger chunk to chew on than I'd planned, but it's good
to know that. It seems like most of the stuff would be fairly simple to
implement - the program I'm working with is built modularly. I've got a
couple of questions that would give me some clarity here on the way though,
if you don't mind:
I notice in your script that you use the multiprocessing library? Are there
any advantages in doing so? It looks to me like you'd be able to accomplish
the same things without using the library so I'd be interested to know why
you chose it.
What do you mean, r.sun can do multithreading? I've heard that r.sun uses
multithreading in GRASS 7, but is that implemented in GRASS 6? Or are you
talking about "poor man's multithreading," like on the GRASS wiki?
I haven't noticed any problems with running r.horizon on GRASS 6.4.2, the
angles looked correct in test data I've used thus far. The maps are all
assigned different names later on and the results look fine, but a lot of
them were missing. I was puzzled for a while because test data worked and
my actual data didn't, but I did a little debugging today and think it's
due to the large size of my study area (~36 km², 0.5m resolution). If I
spatially partition the area and then stitch everything back together, I
hope it works - tests on smaller regions have worked correctly thus far but
I'll need to wait a while to see the real results.
To make a long story short, I'm going to try using the tricks in Markus'
link to get the processes to coexist peacefully and then partition the area
spatially so that it doesn't kill my memory. Hopefully I'll get better
results then. In the meantime you've been a great help :)
Best,
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee at isi-solutions.org
Web: http://www.isi-solutions.org
Am 17. April 2012 21:21 schrieb Collin Bode <collin at berkeley.edu>:
> Lee,
> I tried the same thing, trying to integrate a full workflow in Python for
> r.sun (see attached code). I am using a 2x2 meter lidar elevation map
> with about 120 million cells, so automation is pretty necessary. The whole
> thing takes 3 weeks to run using 8 CPU cores and 12GB ram.
> However, r.horizon does not work properly on Grass 6.4.2. I can only get
> it to run on one core in sequence. I cannot get it to accept a single
> angle and run properly. The output is always for angle 0, both in name
> and output data. Bug? I was planning to post this to the dev list if no
> one responds here.
> It would be worthwhile to find out if your version is simply overwriting
> the previous, similarly named map. If it is, and the maps are actually
> different (r.info), then you can change your code to run r.horizon for a
> single angle, then rename the map. Something like this:
> for azimuth in range(0,361,step_size):
> grass.run_command("r.horizon", elevin=dem, \
> direction=angle, maxdistance=maxdistance,
> horizon=prefhor, dist=dist, overwrite = 1)
> az = str(azimuth).zfill(3)
> tempmap = prefhor+'_0'
> horizonmap = prefhor+'_'+az
> cmd = tempmap+","+horizonmap
> grass.run_command("g.rename",rast=cmd)
> r.sun does work in multiple cores.
> Collin Bode
> Project Manager, Desktop Watershed Integrated Program
> National Center for Earth-surface Dynamics
> University of California, Berkeley
> http://www.nced.umn.edu
> http://ib.berkeley.edu/labs/power
> http://angelo.berkeley.edu
> On Apr 1, 2012, at 5:10 AM, Daniel Lee wrote:
> Hi list,
> I've got a large area I'm running r.horizon on. Since the process takes
> quite a while but it only runs on one processor core and I've got plenty of
> RAM, I've decided to script it in Python and use run_command and
> start_command in order to create multiple horizon maps in parallel. Another
> reason I'm doing it that way is that I only need certain horizons, so I
> don't want GRASS to do all 360°.
> The problem is, when I run the script, all of the maps that I want made
> seem to be made and I can see in top that there are several instances of
> r.horizon. But only the instance to be finished last is actually saved.
> Here's the output:
> Calculating map 1 of 1 (angle 0.000000, raster map <horizon0_0>)
> 100%
> Calculating map 1 of 1 (angle 12.500000, raster map <horizon12.5_0>)
> Calculating map 1 of 1 (angle 7.500000, raster map <horizon7.5_0>)
> Calculating map 1 of 1 (angle 42.500000, raster map <horizon42.5_0>)
> Calculating map 1 of 1 (angle 150.000000, raster map <horizon150.0_0>)
> 100%
> Calculating map 1 of 1 (angle 162.500000, raster map <horizon162.5_0>)
> 100%
> Calculating map 1 of 1 (angle 175.000000, raster map <horizon175.0_0>)
> Calculating map 1 of 1 (angle 167.500000, raster map <horizon167.5_0>)
> Calculating map 1 of 1 (angle 197.500000, raster map <horizon197.5_0>)
> Calculating map 1 of 1 (angle 205.000000, raster map <horizon205.0_0>)
> Calculating map 1 of 1 (angle 225.000000, raster map <horizon225.0_0>)
> 100%
> Calculating map 1 of 1 (angle 257.500000, raster map <horizon257.5_0>)
> Calculating map 1 of 1 (angle 262.500000, raster map <horizon262.5_0>)
> 100%
> Calculating map 1 of 1 (angle 275.000000, raster map <horizon275.0_0>)
> 100%
> Calculating map 1 of 1 (angle 295.000000, raster map <horizon295.0_0>)
> Calculating map 1 of 1 (angle 300.000000, raster map <horizon300.0_0>)
> 100%
> Calculating map 1 of 1 (angle 322.500000, raster map <horizon322.5_0>)
> Calculating map 1 of 1 (angle 325.000000, raster map <horizon325.0_0>)
> 100%
> Calculating map 1 of 1 (angle 337.500000, raster map <horizon337.5_0>)
> Calculating map 1 of 1 (angle 335.000000, raster map <horizon335.0_0>)
> Calculating map 1 of 1 (angle 345.000000, raster map <horizon345.0_0>)
> Calculating map 1 of 1 (angle 350.000000, raster map <horizon350.0_0>)
> 100%
> Calculating map 1 of 1 (angle 352.500000, raster map <horizon352.5_0>)
> 100%
> Calculating map 1 of 1 (angle 355.000000, raster map <horizon355.0_0>)
> 100%
> Calculating map 1 of 1 (angle 357.500000, raster map <horizon357.5_0>)
> 100%
> 100%
> 100%
> 100%
> 100%
> 100%
> 100%
> 100%
> 100%
> But when I do g.list rast at the end of it all I only have these maps:
> raster files available in mapset <Cloppenburg>:
> dom_aspect horizon162.5_0 horizon325.0_0
> dom_complete horizon225.0_0 horizon350.0_0
> dom_slope horizon262.5_0 horizon352.5_0
> horizon0_0 horizon275.0_0 horizon355.0_0
> horizon150.0_0 horizon300.0_0 horizon357.5_0
> As you can see, the only horizon maps saved are the last ones made. Does
> anybody know why this is the case and, if so, what would be a good
> workaround? Finding the horizons serially on only one processor means that
> my computer does a lot of sitting around twiddling thumbs. Thanks a bunch!
> Daniel
> B.Sc. Daniel Lee
> Deutschhausstr. 10
> 35037 Marburg
> ISIS wird gefördert durch die Bundesrepublik Deutschland, Zuwendungsgeber:
> Bundesministerium für Wirtschaft und Technologie aufgrund eines Beschlusses
> des Deutschen Bundestages, sowie durch die Europäische Union,
> Zuwendungsgeber: Europäischer Sozialfonds.
> Zusätzliche Unterstützung erhält ISIS von dem Entrepreneurship Cluster
> Mittelhessen, der Universität Marburg, dem Laboratory for Climatology and
> Remote Sensing und dem GIS-Lab Marburg.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120418/10103586/attachment-0001.html
