[GRASS-user] r.watershed: output basin map
    Margherita Di Leo
    diregola at gmail.com
    Thu Apr 19 03:52:06 EDT 2012
On Thu, Apr 19, 2012 at 12:48 AM, Rich Shepard <rshepard at appl-ecosys.com>wrote:
>  The attached pdf shows the basin map output by r.watershed based on a 10m
> DEM and a threshold of 150000. The NHD level 6 subbasins are outlined in
> black and the 1:24K NHD streams are in blue.
>  The small white areas at the bottom left and center right appear to be
> external to defined sub-basins. But I don't know how to interpret the
> larger
> white areas with streams in them (center and top). The top margin is an
> international boundary so I can understand not being able to completely
> define sub-basins across that boundary since the DEM doesn't reach that far
> north, but it's not consistently white.
>  Please help me interpret the white areas with vector streams.
Please post information about the region, r.info of the map and the command
line of r.watershed that you use. Also, do you use a mask?
Pankaj Kr Sharma, please avoid to reply attaching the whole digest.
Thanks,
madi
Ing. Margherita Di Leo, Ph.D.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120419/74b446e8/attachment.html
