[GRASS-user] Re: <v.triangle> -- module to produce TIN with
"breaklines" using <Triangle> utility
amuriy
amuriy at gmail.com
Sat Apr 21 01:17:32 EDT 2012
Sylvain Maillard wrote
> I'm not sure to understand the difference between your v.triangle and the
> v.delaunay (
> http://grass.osgeo.org/grass64/manuals/html64_user/v.delaunay.html)
> already
> in grass core ... for what I see in your pdf exemple, it seems that your
> new module is giving almost the same result as v.delaunay would do ...
> can you explain the differences ?
The difference exists. <v.delaunay> don't work with "breaklines", e.g. with
constrained Delaunay triangulation, but <Triangle> does (also conforming
triangulation & quality meshing).
About constructing TIN's with "breaklines":
-- http://www.ian-ko.com/resources/triangulated_irregular_network.htm
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/What_is_a_TIN_surface/006000000001000000/
One of problems is "soft" breaklines that not change surface continuity -- I
experimented with them in GRASS, but not through <Triangle>..
P.S. Just try to run <v.triangle>
P.P.S. I will make a page on GRASS-Wiki to explain the work of this module
View this message in context: http://osgeo-org.1560.n6.nabble.com/v-triangle-module-to-produce-TIN-with-breaklines-using-Triangle-utility-tp4903158p4904263.html
Sent from the Grass - Users mailing list archive at Nabble.com.
