[GRASS-user] r.stream.extract: map mis-match error
Rich Shepard
rshepard at appl-ecosys.com
Sun Apr 22 18:17:01 EDT 2012
On Sun, 22 Apr 2012, Markus Metz wrote:
> I guess so because you said that r.stream.extract works with the
> unweighed accumulation map. How exactly did you calculate the weight?
Markus,
r.param.scale in=dem_10m out=tancurv5 size=5 param=crosc
r.param.scale in=dem_10m out=tancurv7 size=7 param=crosc
r.param.scale in=dem_10m out=tancurv11 size=11 param=crosc
r.mapcalc "weight = if(tancurv5 < 0, -100 * tancurv5, if(tancurv7 < 0, -100
* tancurv7, if(tancurv11 < 0, -100 * tancurv11, 0.000001)))"
/* The r.mapcalc command is on a single line; wrapped here. */
r.mapcalc "dem_10m.acc.w = dem_10m.acc * weight"
> BTW, I checked the example script in the manual of r.stream.extract
> and it works in 6.4.3 and 7.0.
With the Spearfish data set, correct? I could extract my data (dem_10m)
and send that for testing purposes. I'm using 6.5svn.
Rich
